CAP - no connections to CAPSMan
Hello guys,
could you help with configuration my AP to Capsman server?
Here is my config:
Capsman server:
[admin@MikroTik] > export
# 2025-03-06 22:30:04 by RouterOS 7.18
# software id = G50G-DC95
# model = RB4011iGS+
# serial number = <removed serial>
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2412 name=channel1
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2437 name=channel6
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2462 name=channel11
add admin-mac=D4:01:C3:DF:FD:A5 auto-mac=no comment=defconf name=bridge
/caps-man datapath
add bridge=bridge name=HomeDatapath
/caps-man security
add authentication-types=wpa2-psk name=securityHome
/caps-man configuration
add channel=channel11 datapath=HomeDatapath distance=indoors installation=indoor mode=ap name=configHome security=securityHome
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
/port
set 0 name=serial0
set 1 name=serial1
/caps-man manager
set enabled=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
/interface ovpn-server server
add mac-address=FE:82:C8:F6:35:27 name=ovpn-server1
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.2 client-id=1:d4:1:c3:4a:a4:22 mac-address=D4:01:C3:4A:A4:22 server=defconf
add address=192.168.88.3 client-id=1:d4:1:c3:d4:70:ef mac-address=D4:01:C3:D4:70:EF server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip ipsec profile
/ip smb shares
set [ find default=yes ] directory=pub
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Bratislava
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
and here is AP configuration
[admin@MikroTikVonka] > export
# 2025-03-06 21:30:11 by RouterOS 7.18
# software id = H32Z-8T71
# model = cAPGi-5HaxD2HaxD
add admin-mac=D4:01:C3:D4:70:EF auto-mac=no comment=defconf name=bridgeLocal
add name=WAN
add name=LAN
/interface wifi datapath
add bridge=bridgeLocal comment=defconf disabled=no name=capdp
/interface wifi
# no connection to CAPsMAN
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap datapath=capdp disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap datapath=capdp disabled=no
add bridge=bridgeLocal comment=defconf disabled=yes interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add interface=ether1 list=WAN
add interface=bridgeLocal list=LAN
/interface wifi cap
set discovery-interfaces=bridgeLocal enabled=yes slaves-datapath=capdp
add address=192.168.88.3/24 interface=bridgeLocal network=192.168.88.0
/ip dhcp-client
/system identity
set name=MikroTikVonka
/system note
Thanks for you help
You configured old capsman on rb4011 while cap is ax device so it needs wave2 capsman.
Remove that config and start again under wifi menu.
I was changed the configuration on main router without Wifi Radio, but same result.
# 2025-03-06 23:06:18 by RouterOS 7.18
# serial number = <serial removed>
/ip hotspot profile
/port
set 0 name=serial0
set 1 name=serial1
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=none
/ip dhcp-client
/ip dns static
/ip ipsec profile
/ip smb shares
The quoted part seems to be the only capsman-related config on your device. Which is very far from enough. You have to do everything under /interface/wifi … the security, datapath, configuration … and finally provisioning. Only after that CAP devices will be able to benefit from your CAPsMAN controller.
yes, its true, its not enough in configuration. I added some atributtes, but same result(CAP - no connections to CAPSMan).
# 2025-03-07 20:35:10 by RouterOS 7.18
add bridge=bridge disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no encryption="" name=HomeSecurity
/interface wifi configuration
add channel.band=2ghz-g datapath=datapath1 datapath.bridge=bridge disabled=no mode=ap name=configHome security=HomeSecurity ssid=DomaciWifi
/ip hotspot profile
/port
set 0 name=serial0
set 1 name=serial1
/interface wifi cap
set caps-man-addresses=192.168.1.26 enabled=yes
set enabled=yes interfaces=bridge package-path="" require-peer-certificate=no upgrade-policy=none
/ip dhcp-client
/ip dns static
/ip ipsec profile
/ip smb shares
Is the CAP connected to ether1 or ether2?
Please consider resetting the CAP into (default) CAPS Mode.
/system/reset-configuration caps-mode=yes
yes, its was mistake on the CAP
add bridge=bridgeLocal comment=defconf disabled=yes interface=ether1,
when I have changed to enabled, Cap is connected to Capsman server.
