Hello everyone! I have problem with cAP and CAPsMANv2:
My hardware:
- Main router - RB3011UiAS - CAPsMAN manager
- 6 pieces cAP
- Not-managed PoE switch
5 of 6 cap normally work, but with the latter there are problems.
If you connect the point directly to the switch, the whole wi-fi network is disconnected.
If you connect to the same switch through the patch panel - packets are not transmitted.
Tried to make a reset - it did not help.
I tried to update the firmware via a non-install - I can not download the firmware.
What to do?
Firmware version for cap - 3.45.4
The usual way I can not update - from 16 MB is used 11.2, the update does not load.
\ - 6 cAP
