cAP2nD Ethernet not working
I´m configuring many cAP2nD devices, everything was fine with all of them, except one. I unplugged it (it turned off) and plugged it again to the POE switch with a different patch cord, it turned on normally but after around 20 seconds the ethernet turned off, wlan is still working and I can connect to it with the default IP 192.168.88.1, but the ethernet dies with every reboot.
If I reboot it, sometimes the ETHERNET goes on for 20 seconds and sometimes it keeps dead. When it is active, the switch detects it as 10Mb connection and half duplex, and it´s not accesible from ETHERNET, just WLAN.
I tried factory reset 100 times, I tried booting into CAPSMAN provisioning mode (it doesn´t get the configuration because ETH is dead), Also tried booting in Netinstall mode and nothing.
One of the things I think I did (not sure) is pressing by mistake the MODE button next to RESET button. I can´t find instructions on what is that button for,
Did someone have this problem? Is there anything I can do? or my ethernet port is fried or something.
I will appreciate any help.
Thanks!
