Enabling CAPs mode
To connect this device to a wireless network managed by CAPsMAN, keep holding the button for 5 more seconds, LED turns solid, release now to turn on CAPs mode (total 10 seconds)
This is super convenient but im lazy so i wrote a script so dont have to log in to the cap and set a admin password and other settings that we need/want.
The script leverages the dhcp lease script feature on new leases, checks against capsman if the mac-address is a remote cap and against a logfile containing mac-address of cap’s allready configured. If all is well it uploads “capconfig.auto.rsc” by ftp to the cap and add its mac-address to the logfile.
I hope someone else find it useful
# CAP Config
# Configure CAP's automatically utilizing automatic import
# https://wiki.mikrotik.com/wiki/Manual:Configuration_Management
# For each lease offered by the dhcp server the script
# will run and check if the clients mac-address is a remote cap in capsman and
# check if the mac-address is not in the log file "capconfig.log.txt".
# Only then the script will upload "capconfig.auto.rsc" by ftp to the cap and add
# it's mac-address to "capconfig.log.txt"
# Howto:
# Edit capconfig.auto.rsc with your settings and
# upload it to capsman controller
# Add lease script on the dhcp server: CAPConfig
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
# EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
# MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
# IN NO EVENT SHALL THE AUTHORS BE LIABLE FOR ANY CLAIM, DAMAGES OR
# OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
# ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
# OTHER DEALINGS IN THE SOFTWARE.
# Henrik Eliasson
# https://github.com/internethero
# Tested on RB2011UAS RouterOS V6.38.3
:local user admin
:local password
:local ftpdelay 5s
:local autoscript capconfig.auto.rsc
:local log
:local logfile "capconfig.log.txt"
# Check if its a cap
if ($leaseBound = 1) do={
if ([/caps-man remote-cap find where name="[$leaseActMAC]"] != "") do={
# Create log file if it does not exists
:if ([:len [/file find name=$logfile]] = 0) do={
/file print file=$logfile
delay 2
/file set $logfile contents=","
:delay 1
# Read contents of logfile to variable
:set $log [/file get $logfile contents]
# Check if CAP mac is in the logfile
if ([:find $log $leaseActMAC -1] >= 0) do={
#nothing
} else {
#CAP not in logfile, uploading config...
:log warn ("[CAP Config] Uploading config",$autoscript," to CAP", $leaseActIP)
/tool fetch address="$leaseActIP" src-path=$autoscript user=$user mode=ftp password=$password dst-path="/$autoscript" upload=yes
delay $ftpdelay
/file set $logfile contents=($log . $leaseActMAC)
# Set admin password
/user set admin password="pa$$word"
# Disable telnet mac server
/tool mac-server set [ find default=yes ] disabled=yes
# Disable mac winbox
/tool mac-server mac-winbox set [ find default=yes ] disabled=yes
# Disable services
/ip service
set telnet disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
