CAPMANS and VLAN's (not routing traffic)
Hello;
I am trying to setup a dedicated CAPSMAN server VM. When my clients connect, they cannot get on the appropriate VLAN set. I have followed the appropriate guides on these forums and unable to make it work.
The VM has the following interfaces:
  1. VLAN99 (aka mgmt)
  2. VLAN20
  3. VLAN30
  4. VLAN99
I have tested the virtual networks with other VM’s and they do route traffic as expected.
Mikrotik VM is running 7.7.
add name=bridge1 vlan-filtering=yes
set [ find default-name=ether1 ] disable-running-check=no name=mgmt
set [ find default-name=ether2 ] disable-running-check=no name=vlan20
set [ find default-name=ether3 ] disable-running-check=no name=vlan30
set [ find default-name=ether4 ] disable-running-check=no name=vlan99
/caps-man configuration
add datapath.bridge=bridge1 .vlan-id=20 .vlan-mode=use-tag name=VLAN20
security.authentication-types=wpa2-psk ssid=VLAN20
add datapath.bridge=bridge1 .vlan-id=30 .vlan-mode=use-tag name=VLAN30
security.authentication-types=wpa2-psk ssid=VLAN30
add datapath.bridge=bridge1 .vlan-id=99 .vlan-mode=use-tag name=VLAN99
security.authentication-types=wpa2-psk ssid=VLAN99
/port
set 0 name=serial0
set 1 name=serial1
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=mgmt
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=VLAN20 name-format=
prefix-identity slave-configurations=VLAN99,VLAN30
add bridge=bridge1 interface=vlan20 pvid=20
add bridge=bridge1 interface=vlan30 pvid=30
add bridge=bridge1 interface=vlan99 pvid=99
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 untagged=vlan20 vlan-ids=20
add bridge=bridge1 tagged=bridge1 untagged=vlan30 vlan-ids=30
add bridge=bridge1 tagged=bridge1 untagged=vlan99 vlan-ids=99
/ip dhcp-client
add interface=mgmt
/system clock
set time-zone-name=America/Toronto
Any ideas?
