I tried to use the CAPs Manager for the new AX devices. But this is a pre alpha than useable.
I have big problems to get the mANTBox to work.
This is the CAPs config.
add admin-mac=F4:1E:57:00:71:AA auto-mac=no name=bridge
set [ find default-name=ether8 ] poe-out=forced-on
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi configuration
add antenna-gain=0 country=Switzerland datapath.vlan-id=99 disabled=no mode=\
ap name=Public_AX security.authentication-types=wpa2-psk \
.group-key-update=1h ssid=XXXX
/interface wifi
add configuration=Public_AX configuration.mode=ap disabled=no name=cap-wifi1 \
radio-mac=D4:01:C3:97:DC:76
add configuration=Public_AX configuration.mode=ap disabled=no name=cap-wifi2 \
radio-mac=D4:01:C3:97:DC:77
/interface wifi datapath
add disabled=no name=Public
/port
set 0 name=serial0
add bridge=bridge interface=ether2
add bridge=bridge interface=ether1
add bridge=bridge interface=ether8
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=\
none
/ip dhcp-client
add comment=defconf interface=bridge
set allow-remote-requests=yes
/ipv6 firewall address-list
/system clock
set time-zone-name=Europe/Vienna
/system note
set show-at-login=no
/system routerboard settings
set auto-upgrade=yes enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
If i check the wifi interface it shows onder TX Power only 7 on the 2.4Ghz and 15 under the 5.5 Ghz interface.
Why is there only 7 and 15dbm?
Also the 5.5 Ghz is checking allways for 10 min. I cant set it to 1min.
Screenshot:
https://ibb.co/hfcPh6b
