CAP's ident conflict
Hello All,
I have problem with 1 of 4 APs which are managed by CAPsMAN. For AP01 I get errors:
10:02:25 caps,info [::ffff:10.1.100.11:43729,Join,[6C:3B:6B:42:C7:7B]] joined, pro
vides radio(s): 6C:3B:6B:42:C7:7C
10:02:29 caps,info OGR-AP01-1: selected channel 2412/20-Ce/gn(20dBm)
10:02:56 [b]caps,error removing stale connection [::ffff:10.1.100.11:43729,Run,[6C:3B
:6B:42:C7:7B]] because of ident conflict with [::ffff:10.1.100.11:37543,Join,[6C:3
B:6B:42:C7:7B]] [/b]
10:02:56 caps,info [::ffff:10.1.100.11:37543,Join,[6C:3B:6B:42:C7:7B]] joined, pro
10:03:00 caps,info OGR-AP01-1: selected channel 2457/20-eC/gn(20dBm)
10:03:22 dhcp,info server-vlan192 deassigned 192.168.0.167 from 10:9A:B9:01:24:4A
10:03:22 dhcp,info server-vlan192 assigned 192.168.0.167 to 10:9A:B9:01:24:4A
10:03:27 caps,error removing stale connection [::ffff:10.1.100.11:37543,Run,[6C:3B
:6B:42:C7:7B]] because of ident conflict with [::ffff:10.1.100.11:38221,Join,[6C:3
B:6B:42:C7:7B]]
10:03:27 caps,info [::ffff:10.1.100.11:38221,Join,[6C:3B:6B:42:C7:7B]] joined, pro
10:03:30 caps,info OGR-AP01-1: selected channel 2452/20-Ce/gn(20dBm)
10:03:58 caps,error removing stale connection [::ffff:10.1.100.11:38221,Run,[6C:3B
:6B:42:C7:7B]] because of ident conflict with [::ffff:10.1.100.11:33405,Join,[6C:3
B:6B:42:C7:7B]]
10:03:58 caps,info [::ffff:10.1.100.11:33405,Join,[6C:3B:6B:42:C7:7B]] joined, pro
10:04:01 caps,info OGR-AP01-1: selected channel 2452/20-Ce/gn(20dBm)
10:04:25 caps,info 20:78:F0:E5:F4:BA@OGR-AP03-1-1 connected, signal strength -85
10:04:29 [b]caps,error removing stale connection [::ffff:10.1.100.11:33405,Run,[6C:3B
:6B:42:C7:7B]] because of ident conflict with [::ffff:10.1.100.11:60123,Join,[6C:3
10:04:29 caps,info [::ffff:10.1.100.11:60123,Join,[6C:3B:6B:42:C7:7B]] joined, pro
10:04:32 caps,info OGR-AP01-1: selected channel 2452/20-Ce/gn(20dBm)
10:05:00 [b]caps,error removing stale connection [::ffff:10.1.100.11:60123,Run,[6C:3B
:6B:42:C7:7B]] because of ident conflict with [::ffff:10.1.100.11:58957,Join,[6C:3[/b]
AP01 is being disconnected and connected again. Cable is OK (different AP works fine on it). Other APs work fine.
I noticed double cerificates on CAPsAMN, so I revoked both of them:
[xadmin@OGR-R01] > /certificate print
Flags: K - private-key, D - dsa, L - crl, C - smart-card-key, A - authority, I - issued, R - revoked, E - expired, T - trusted
 #          NAME                                           COMMON-NAME                                          SUBJECT-ALT-NAME        FINGERPRINT
 0 K   A  T CAPsMAN-CA-5B7AC357B87B                        CAPsMAN-CA-5B7AC357B87B        26009078e9ccb588551ec5f3bc07111862a30f8e1ce3c53f3...
 1 K    I   CAPsMAN-5B7AC357B87B                           CAPsMAN-5B7AC357B87B        ce3144151deb29bf108fc90cb9154a93ee5b06dc2b2db871d...
 2      I   CAP-CC2DE0319484                               CAP-CC2DE0319484        06d11669629ddd8e03a8f44abdfa0d1e28048d83c04aba67c...
 3      I   CAP-CC2DE031945C                               CAP-CC2DE031945C        4132657301f6c6c13b208461c31e8bd8063751887265923f1...
 4      R   CAP-6C3B6B42C77B-old                           CAP-6C3B6B42C77B        4e768bbc9732f2e6fd00ca26766b42a882fc5d2877eea5f3b...
 5      I   CAP-CC2DE031945E                               CAP-CC2DE031945E        ef9dfb378f0f18eb8029208598d515d38b04095131dc65638...
 6      R   CAP-6C3B6B42C77B-old2                          CAP-6C3B6B42C77B        36382215b18a57ccc06f976c317614968df12ab6d1672debc...
[xadmin@OGR-R01] >
It didn’t help.
Do you have any suggestions what might be wrong?
BR/Eliash
For those who had the same problem: Solution is to manually set MAC address for Ap’s bridge. Use Ether1 MAC address.
BR/Eliash
Hi @Neferith, I got the same issue :
caps,error removing stale connection [mac_add/13/fef4,Run,CAP-mac_add] because of ident conflict with [mac_address/13/2b39,join,CAP,MAC_address]
I am fairly new on mikrotik and I not understand how to implement your solution.
Could you please explain how you did that and if (after so long time) the problem was fixed and stable?
I’m having the same issue, briege MAC Address on both AP are using AP’s ether1 MAC Address. My Bridge has a static IP Address and I’m still getting that error logged and my SSIDs droping when it happens.
I someone else has any additional help I will appreciate it.
