CAPS MAN Problem with DNS??
First of all I am new to Mikrotik so excuse me any “dum” questions!!
I have my home setup with a RB951Ui-2HnD as main router and CAPS MANAGER,
and a second one as CAP na hAP lite.
I have setup the system ok (with your silent help, Reading the fóruns and Wiki´s), evething is running ok expect two things.
  • on the CAP if i try to check for update version I get “ERROR: could not resolve dns name” if I try to use the ping tool on the CAP I can ping the network inside but i can not ping the CAPSMANAGER neither na outsider ip or URL.
    I can bypass the ping problems this if i use the bridge1 interface and arp ping, but i get the same DNS error.
I can connect to the internet with no problems, the only problema i have left is chromecast not connecting to the WIFI but I beleive the first problema need to be resolved before I can solve the other one.
What am I doing wrong.
I leave my configurations bellow.
CAPSMAN
# apr/05/2016 15:13:27 by RouterOS 6.35rc45
# software id = YZTI-7DGK
/caps-man channel
add band=2ghz-b/g/n extension-channel=disabled frequency=2412 name=channel1 width=20
add band=2ghz-b/g/n extension-channel=disabled frequency=2437 name=channel6 width=20
add admin-mac=E4:8D:8C:83:B3:5F arp=proxy-arp auto-mac=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway tx-flow-control=auto
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=ether5-slave-local
/interface wireless
# managed by CAPsMAN
# channel: 2437/20/gn(20dBm), SSID: MATWIFI, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC country=portugal frequency=\
    auto mode=ap-bridge ssid=MATWIFI wds-default-bridge=bridge-local wireless-protocol=802.11
add mac-address=E6:8D:8C:83:B3:63 master-interface=wlan1 name=wlan2 ssid="MATWIFI's Guests"
/ip neighbor discovery
set ether1-gateway discover=no
/caps-man datapath
add bridge=bridge-local client-to-client-forwarding=yes local-forwarding=no name=datapath1
add bridge=bridge-local local-forwarding=no name=datapath2
/caps-man security
add authentication-types=wpa-psk,wpa2-psk,wpa-eap,wpa2-eap encryption=aes-ccm,tkip name=security1 \
    passphrase=*************
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=security2 passphrase=*********
/caps-man configuration
add country=portugal datapath=datapath1 mode=ap name=cfg1 security=security1 ssid=MATWIFI
add country=portugal datapath=datapath2 mode=ap name=cfg2 security=security2 ssid=MATWIFI_GUEST
/caps-man interface
add arp=enabled channel=channel6 configuration=cfg1 disabled=no l2mtu=1600 mac-address=\
    E4:8D:8C:83:B3:63 master-interface=none mtu=1500 name=cap1 radio-mac=E4:8D:8C:83:B3:63
add arp=enabled channel=channel1 configuration=cfg2 disabled=no l2mtu=1600 mac-address=\
    E6:8D:8C:83:B3:63 master-interface=cap1 mtu=1500 name=cap1-1 radio-mac=00:00:00:00:00:00
add arp=enabled channel=channel1 configuration=cfg1 disabled=no l2mtu=1600 mac-address=\
    E4:8D:8C:C8:0B:7C master-interface=none mtu=1500 name=cap2 radio-mac=E4:8D:8C:C8:0B:7C
    E6:8D:8C:C8:0B:7C master-interface=cap2 mtu=1500 name=cap2-1 radio-mac=00:00:00:00:00:00
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys \
    supplicant-identity=MikroTik wpa-pre-shared-key=******** wpa2-pre-shared-key=********
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
add name=dhcp ranges=192.168.1.1-192.168.1.100
add name=vpn ranges=192.168.1.101-192.168.1.110
add add-arp=yes address-pool=dhcp always-broadcast=yes authoritative=yes disabled=no interface=\
    bridge-local lease-time=1d name=DHCP_principal
/ppp profile
set *FFFFFFFE incoming-filter="" local-address=192.168.1.1 remote-address=vpn use-compression=yes \
    use-mpls=yes
/caps-man access-list
add action=accept client-to-client-forwarding=yes disabled=no interface=all mac-address=\
    00:00:00:00:00:00 signal-range=-70..120 ssid-regexp=""
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes require-peer-certificate=yes upgrade-policy=\
    suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg1 slave-configurations=cfg2
/interface bridge filter
# no interface
add action=drop chain=forward in-interface=wlan2
# no interface
add action=drop chain=forward out-interface=wlan2
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add bridge=bridge-local interface=wlan2
/interface ethernet switch host
add mac-address=00:08:9B:C2:B1:44 ports=ether5-slave-local switch=switch1
/interface l2tp-server server
set allow-fast-path=no authentication=mschap1,mschap2 enabled=yes ipsec-secret=ekimuth#07 \
    max-sessions=unlimited use-ipsec=yes
/interface ovpn-server server
set cipher=blowfish128,aes128,aes192,aes256 default-profile=default-encryption enabled=yes
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=yes
/interface wireless cap
set caps-man-certificate-common-names=CAPsMAN-E48D8C83B35E certificate=CAP-E48D8C83B35E \
    discovery-interfaces=bridge-local enabled=yes interfaces=wlan1 lock-to-caps-man=yes
add address=192.168.1.1/24 comment="Endere\E7o Rede Principal" interface=ether2-master-local network=\
    192.168.1.0
add address=192.168.1.2/24 comment="Endere\E7o Guest wifi" interface=ether2-master-local network=\
    192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=\
    ether1-gateway
/ip dhcp-server config
set store-leases-disk=immediately
/ip dhcp-server lease
add address=192.168.1.10 client-id=ff:eb:3f:f4:81:0:1:0:1:1c:dd:61:2:b8:27:eb:3f:f4:81 comment=\
    "REPETIER SERVER" mac-address=B8:27:EB:3F:F4:81 server=DHCP_principal
add address=192.168.1.223 client-id=1:0:0:74:a4:ef:df comment="Scanner Ricoh" mac-address=\
    00:00:74:A4:EF:DF server=DHCP_principal
add address=192.168.1.0/24 caps-manager=192.168.1.1 comment="default configuration" dns-server=\
    8.8.8.8,192.168.1.1,8.8.4.4 gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes cache-max-ttl=1d cache-size=4048KiB servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.1.2 name=router
add action=drop chain=forward comment="Isola rede local da Guest" disabled=yes dst-address=\
    192.168.2.0/24 src-address=192.168.1.0/24
    192.168.1.0/24 src-address=192.168.2.0/24
    "As duas regras seguintes impedem requests externos de DNS ao router" dst-port=53 in-interface=\
    ether1-gateway protocol=tcp
add action=drop chain=input dst-port=53 in-interface=ether1-gateway protocol=udp
add chain=input comment="default configuration" protocol=icmp
add chain=forward comment="default configuration" connection-state=established,related,new
add chain=input comment="default configuration" connection-state=established,related,new
add chain=input comment="Allow limited pings" limit=50/5s,2:packet protocol=icmp
add chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=drop chain=input comment="Recusa pedidos de fora" in-interface=ether1-gateway
add action=drop chain=forward comment="N\E3o Faz Forward de Pacotes invalidos" connection-state=\
    invalid
add action=drop chain=forward comment="default configuration" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
add action=dst-nat chain=dstnat comment="QNAP WWW" dst-port=8082 protocol=tcp to-addresses=\
    192.168.1.251 to-ports=8082
add action=dst-nat chain=dstnat comment="REPETIER SERVER WEBCAM" dst-port=8083 protocol=tcp \
    to-addresses=192.168.1.10 to-ports=8083
add action=dst-nat chain=dstnat comment="REPETIER SERVER" dst-port=3344 protocol=tcp to-addresses=\
    192.168.1.10 to-ports=3344
add action=masquerade chain=srcnat comment="masq. vpn traffic" disabled=yes src-address=\
    192.168.89.0/24
add action=masquerade chain=srcnat comment="Acesso via DNS interno RPI REPETIER SERVER" dst-address=\
    192.168.1.10 dst-port=3344 out-interface=bridge-local protocol=tcp src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment="Acesso via DNS interno RPI REPETIER SERVER - VIDEO" \
    dst-address=192.168.1.10 dst-port=8083 out-interface=bridge-local protocol=tcp src-address=\
    192.168.1.0/24
add action=masquerade chain=srcnat comment="Acesso via DNS interno QNAP" dst-address=192.168.1.251 \
    dst-port=8082 out-interface=bridge-local protocol=tcp src-address=192.168.1.0/24
/ip firewall service-port
set irc disabled=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set show-dummy-rule=no
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=ether1-gateway type=external
/ppp secret
add name=******** password=********* profile=default-encryption
/system clock
set time-zone-name=Europe/Lisbon
/system identity
set name=Sala
/system ntp client
set enabled=yes primary-ntp=194.117.9.130
/system package update
set channel=release-candidate
/tool graphing interface
add interface=wlan1
add interface=cap1
add interface=cap1-1
add interface=cap2
add interface=cap2-1
add
add interface=wlan2
add
/tool mac-server
add interface=ether2-master-local
add interface=wlan1
add interface=wlan2
/tool mac-server mac-winbox
add interface=wlan1
add interface=wlan2
/tool traffic-monitor
add interface=bridge-local name=tmon1 threshold=0
CAP
# mar/28/2016 12:29:30 by RouterOS 6.35rc45
# software id = F6B5-1ECZ
add name=bridge1
/interface wireless
# channel: 2412/20/gn(20dBm), SSID: MATWIFI, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
add bridge=bridge1 interface=wlan1
set allow-fast-path=no max-sessions=unlimited
set bridge=bridge1 caps-man-certificate-common-names=CAPsMAN-E48D8C83B35E certificate=CAP-E48D8CC80B78 \
    discovery-interfaces=ether1 enabled=yes interfaces=wlan1 lock-to-caps-man=yes
add address=192.168.1.2/24 interface=ether2 network=192.168.1.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no interface=bridge1
add distance=1 gateway=192.168.1.1
/system clock
/system identity
set name=Quarto
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
Thank you in advance for your time in helping me.
Miguel Matias
Hi All,
Problem solved after days i found out what the problem was, on the IP/ADRESS LIST there was a ip conflito
[/add address=192.168.1.2/24 comment=“Endereço Guest wifi” interface=ether2-master-local network=
192.168.1.0
This was a leftover from the initial configuration of the router.
in resume CAPSMAN MANAGER had on eth2 the same IP as the CAP Bridge, and of course problems !!!
Thank you all that read my post to try to help, I did solved it but I left this it here for future reference .
