CAPS not provisioned
After two years of not working with networking I’m feeling like a noob when returning. I’m probably missing some details in the config.
I’ve setup a capsman (3011) and some caps. All caps behave the same, so I focus on one of them, a cAP. The cap is connecting to capsman, but it (they) does not get any configuration. Also, the caps only shows two interfaces, it should be 14 (7 ssid’s/vlan with two radios). To me it seems like the caps connects, but for some reason it does not find it’s configuration. It does not make a difference if I empty the Identity Regexp in capsman provisioning.
EDIT: removing all lines of config except for those that caused trouble
Capsman config:
/caps-man configuration
add channel.reselect-interval=1d country=norway datapath=datapath40 mode=ap name=> wlan40 > security=sec40 ssid=wlan40
add country=norway datapath=datapath41 mode=ap name=> wlan41 > security=sec41 ssid=wlan41
add country=norway datapath=datapath42 mode=ap name=> wlan42 > security=sec42 ssid=wlan42
add country=norway datapath=datapath43 mode=ap name=> wlan43 > security=sec43 ssid=wlan43
add country=norway datapath=datapath44 mode=ap name=> wlan44 > security=sec44 ssid=wlan44
add country=norway datapath=datapath45 mode=ap name=> wlan45 > security=sec45 ssid=wlan45
add country=norway datapath=datapath46 mode=ap name=> wlan46 > security=sec46 ssid=wlan46
/caps-man provisioning
add action=create-dynamic-enabled identity-regexp=“^al[h|w|c]ap[0-9]*” master-configuration=> wlan40 > name-format=prefix-identity name-prefix=cap
slave-configurations=> wlan41,wlan42,wlan43,wlan44,wlan45,wlan46
Solved!
It turns out that the naming of the capsman configurations was the problem. A wlan configuration named “wlan40”, “wlan41”, … causes some conflicts.
Feature request: Give a error when a conflicting name is set. (just the same way as when trying to create a firewall rule with an invalid ip/subnet)
