The following code ist from the CAPS Manager
# 2025-01-12 16:35:11 by RouterOS 7.16.2
# software id = GPPW-PYP5
# model = RB1100Dx4
# serial number = xxxxxxxx
/caps-man channel
add band=5ghz-a/n/ac name=WLAN50
add band=2ghz-b/g/n extension-channel=Ce name=WLAN24
add name=bridge_ethernet port-cost-mode=short
add name=bridge_service
set [ find default-name=ether1 ] comment="FritzBox Internet" mac-address=\
D4:01:C3:FB:B2:2B
set [ find default-name=ether2 ] mac-address=D4:01:C3:FB:B2:2C
set [ find default-name=ether3 ] mac-address=D4:01:C3:FB:B2:2D
set [ find default-name=ether4 ] mac-address=D4:01:C3:FB:B2:2E
set [ find default-name=ether5 ] mac-address=D4:01:C3:FB:B2:2F
set [ find default-name=ether6 ] mac-address=D4:01:C3:FB:B2:30
set [ find default-name=ether7 ] mac-address=D4:01:C3:FB:B2:31
set [ find default-name=ether8 ] mac-address=D4:01:C3:FB:B2:32
set [ find default-name=ether9 ] mac-address=D4:01:C3:FB:B2:33
set [ find default-name=ether10 ] mac-address=D4:01:C3:FB:B2:34
set [ find default-name=ether11 ] comment=Bypass mac-address=\
D4:01:C3:FB:B2:35
set [ find default-name=ether12 ] comment=Bypass mac-address=\
D4:01:C3:FB:B2:36
set [ find default-name=ether13 ] comment="Leer PPOE" mac-address=\
D4:01:C3:FB:B2:37
/caps-man interface
add disabled=no l2mtu=1600 mac-address=08:55:31:47:C5:36 master-interface=\
none name=cap1 radio-mac=08:55:31:47:C5:36 radio-name=08553147C536
add disabled=no l2mtu=1600 mac-address=08:55:31:47:C5:37 master-interface=\
none name=cap2 radio-mac=08:55:31:47:C5:37 radio-name=08553147C537
add disabled=no l2mtu=1600 mac-address=08:55:31:48:CE:2E master-interface=\
none name=cap3 radio-mac=08:55:31:48:CE:2E radio-name=08553148CE2E
add disabled=no l2mtu=1600 mac-address=08:55:31:48:CE:2F master-interface=\
none name=cap4 radio-mac=08:55:31:48:CE:2F radio-name=08553148CE2F
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security
/disk
set sata1 comment=Intern1SSD media-interface=none media-sharing=no
set sd1 comment="externe SD-Karte" media-interface=none media-sharing=no
add name=WAN
add name=LAN
add name=caps_interfaces
/caps-man datapath
add bridge=bridge_ethernet bridge-cost=5 client-to-client-forwarding=yes \
interface-list=caps_interfaces local-forwarding=yes name=datapath1
/caps-man configuration
add channel=WLAN50 country="germany 5.8 ap" datapath=datapath1 distance=\
dynamic installation=outdoor max-sta-count=250 mode=ap name=cfg50 \
security=security ssid=SSID
add channel=WLAN24 country=germany datapath=datapath1 distance=dynamic \
installation=outdoor max-sta-count=250 mode=ap name=cfg24 security=\
security ssid=SSID
/interface lte apn
add interface=ether1 name=server1
add name=dhcp_Master ranges=\
192.110.0.1-192.110.10.0,192.110.10.2-192.110.15.254
add name=dhcp_pool2 ranges=170.205.20.1-170.205.20.253
add address-pool=dhcp_Master interface=bridge_ethernet lease-time=5m name=\
dhcp2
add address-pool=dhcp_pool2 interface=bridge_service name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
/system logging action
add disk-file-count=20 disk-file-name=sd1/Log/logfile disk-lines-per-file=\
65535 disk-stop-on-full=yes name=Meldung target=disk
/caps-man manager
set enabled=yes upgrade-policy=require-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add comment=Ethernet disabled=no interface=bridge_ethernet
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=\
cfg50
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=\
cfg24
add bridge=bridge_ethernet interface=ether2 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether3 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether4 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether12 internal-path-cost=10 path-cost=\
10
add bridge=bridge_service interface=ether11 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether5 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether6 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether7 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether8 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether9 internal-path-cost=10 path-cost=\
10
add bridge=bridge_ethernet interface=ether10 internal-path-cost=10 path-cost=\
10
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add interface=bridge_ethernet list=LAN
add interface=bridge_service list=LAN
add comment=Internet interface=ether1 list=WAN
add interface=bridge_ethernet list=caps_interfaces
/interface ovpn-server server
set auth=sha1,md5
add address=192.110.10.1/20 interface=bridge_ethernet network=192.110.0.0
add address=170.205.20.254/24 comment="Service Port 11" interface=\
bridge_service network=170.205.20.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.110.9.240 client-id=1:40:ed:cf:51:1f:29 mac-address=\
40:ED:CF:51:1F:29 server=dhcp2
add address=192.110.9.235 client-id=1:98:fc:84:12:b:18 mac-address=\
98:FC:84:12:0B:18 server=dhcp2
add address=170.205.20.0/24 dns-server=192.168.178.1,192.110.10.1 gateway=\
170.205.20.254
add address=192.110.0.0/20 dns-server=192.110.10.1 gateway=192.110.10.1
set allow-remote-requests=yes servers=192.110.10.1
established,related,untracked
invalid
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
connection-state=invalid
add action=accept chain=forward comment="allow internet traffic" \
in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" \
connection-nat-state=dstnat
add action=drop chain=forward
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface-list=\
WAN
/ip ipsec profile
/ip packing
add interface=ether12
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
/system identity
set name=Mikrotik_Name
/system logging
set 0 action=Meldung
set 1 action=Meldung
set 2 action=Meldung
/system note
set show-at-login=no
/system ntp server
set broadcast=yes enabled=yes multicast=yes
This is the running client code:
# 2025-01-12 16:44:59 by RouterOS 7.16.2
# software id = XS3I-GXRB
# model = RB952Ui-5ac2nD
# serial number = xxxxxxxxx
add admin-mac=08:55:31:47:D9:CE auto-mac=no comment=defconf name=\
/interface wireless
# managed by CAPsMAN
# channel: 2412/20-Ce/gn(18dBm), SSID: SSIDXXX, local forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
disabled=no distance=indoors frequency=auto installation=indoor mode=\
bridge ssid=MikroTik-47D9D3 station-roaming=enabled wireless-protocol=\
802.11
# channel: 5765/20-Ceee/ac(19dBm), SSID: SSIDXXX, local forwarding
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
installation=indoor mode=bridge ssid=MikroTik-XXXX station-roaming=\
enabled wireless-protocol=802.11
set [ find default-name=ether1 ] comment="Input"
set [ find default-name=ether5 ] comment="Output"
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add bridge=bridge_ethernet interface=wlan2
add bridge=bridge_ethernet interface=wlan1
set udp-timeout=10s
/ip settings
/ipv6 settings
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=wlan2 list=LAN
add interface=wlan1 list=LAN
/interface wireless cap
set bridge=bridge_ethernet caps-man-addresses=192.110.10.1 enabled=yes \
interfaces=wlan2,wlan1
/ip dhcp-client
/ip ipsec profile
/system clock
/system identity
set name="MikroTik-1"
/system note
/tool mac-server
/tool mac-server mac-winbox
The reset (including Factory settings) we did already.
When I made the files, I did also the one for the non running version. This file is much shorter, although the non running router was gernerated by a backup from the running one
# 2025-01-12 16:44:09 by RouterOS 7.16.2
# software id = 4NJY-2DE9
# serial number = XXXXXXXXXX
/interface wireless
# channel: 5785/20-eeCe/ac(28dBm), SSID: , CAPsMAN forwarding
set [ find default-name=wlan2 ] ssid=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name=profile1 \
supplicant-identity=""
/interface wireless
# channel: 2412/20-Ce/gn(28dBm), SSID: , CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=germany installation=\
outdoor mode=ap-bridge security-profile=profile1 ssid=MikroTik wps-mode=\
disabled
/ip dhcp-client
/system clock
/system identity
set name="MikroTik-5"
/system note
