CAPsMAN 2.4 & 5 GHz same SSID
Hello there,
I recently moved from Unifi to Mikrotiks Audience and run the Wifi via CAPsMAN.
What is a bit weird to me is, if setup just SSIDs with authentication (like for a home AP) I receive any SSID at 2.4 & 5 GHz.
As soon as I create a dedicated channel setting and use it for my SSIDs, I only get 2.4 GHz.
Even though I already copied each configuration to the channels and put the new configuration to the provisioning tab.
Any ideas what I am doing wrong?
Solved → http://forum.mikrotik.com/t/solved-capsman-wap-ac-5ghz-no-supported-band-united-states-3/111709/6
