I have CAPsMAN controller on CHR (6.42), some APs on HAP ac lite (6.42), working configuration where master interface have SSID with WPA2-EAP (through radius server) and virtual SSID without security (Open). Then I try to add to this configuration one more virtual interface with WPA2-PSK, SSID with EAP stop working. I still see broadcast of this SSID, but can’t connect to it and even not see connection attempts in CAPsMAN logs. Open and WPA2-PSK networks on virtual interfaces works fine on this time. When I disable or delete WPA2-PSK virtual interface, WPA2-EAP start working.
This is error or WPA2-EAP and WPA2-PSK can’t work on one physical interface even in different virtual interfaces?
