CAPsMAN 2 SSID's with 2 different Radius servers
Is it possible to use CAPsMAN and have multiple SSIDs and use for some SSID’s WPA2 enterprise with different Radius servers?
I Ask this because I have Multiple VLANs and each VLAN has its own SSID and also have a guest network. For the production network we want to use Radius authentication from the Windows 2008 R2 active directory NPS but for guest we need an other radius server with other users and profiles.
U can specify d different Radius Server IPs on the hotspot settings, I mean the Hotspot Server Profiles
I need it also and I am not using hotspot.
I just have 2 different SSIDs/subnets which should use different Radius Servers.
Any idea?
I also not use hotspot but need really 2 different radius servers.
Anybody?
Any help would be appreciated.
All I want is to define different Radius servers for different SSIDs without hotspots!
SSID1 radius1
SSID2 radius2
In RouterOS v6.43rc12 we will have a called-station-id-type setting in the wireless security profile and in the CAPsMAN AAA section where you could specify what to include in the called-station field for the radius client. By default it would be MAC:SSID and you will be able to select just the MAC or just the SSID. Then it would help you to make just one Radius Client entry for all the APs.
For me please too - is any way how to configure different radius server for different SSID in WPA2 EAP mode ?
Thanks Uldis! I see the radius-called-format under the standard wireless security profile. Any chance this will make it in to the CAPsMAN security configuration?
