CapsMan 5ghz Channels
is there list of Channels to use on 5Ghz band for use with CapsMan.
On 2.4 I use non overlapping channels 1, 6, 11, but what to use on 5Ghz?
It depends on the set country code (regulations) and channelwidth:
Regulatory is europe, italy and channel width would be 20 or 40mhz.
What is best practice and then what channels to use?
Each channel is 20MHz wide, so you do the math. If I remember correct 40MHz is giving less problems…
OkayI understanf that but which bands to use?
I space them 40mhz so they don’t overlap?
I used 36, 40 and 44 @ 20 Mhz.
Regards.
