I have RB3011 UiAS-RM + multple cAP ac. Every device is running ROS 6.45.1.
Problem is when I configure CAPsMAN on RB3011 (192.168.2.1) and enable Wireless CAP on cAP (192.168.2.205). Connection establishes between controller and device and the device is configured automatically.
Here is the config of CAPsMAN
# jul/15/2019 12:22:34 by RouterOS 6.45.1
# software id = SUKN-JHUB
# model = RouterBOARD 3011UiAS
# serial number = 8EED0ADD4261
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2412 name=channel1
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2442 name=channel6
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2472 name=channel11
add band=5ghz-a/n/ac frequency=5180 name=CH36
add band=5ghz-onlyac control-channel-width=20mhz extension-channel=eCee frequency=5200 \
name=CH40 tx-power=3
add band=5ghz-a/n/ac frequency=5220 name=CH44
add band=5ghz-a/n/ac frequency=5240 name=CH48
add band=5ghz-a/n/ac frequency=5260 name=CH52
add band=5ghz-a/n/ac frequency=5280 name=CH56
add band=5ghz-a/n/ac frequency=5300 name=CH60
add band=5ghz-a/n/ac frequency=5320 name=CH64
add band=5ghz-a/n/ac frequency=5500 name=CH100
add band=5ghz-a/n/ac frequency=5520 name=CH104
add band=5ghz-a/n/ac frequency=5540 name=CH108
add band=5ghz-a/n/ac frequency=5560 name=CH112
add band=5ghz-a/n/ac frequency=5580 name=CH116
add band=5ghz-a/n/ac frequency=5600 name=CH120
add band=5ghz-a/n/ac frequency=5620 name=CH124
add band=5ghz-a/n/ac frequency=5640 name=CH128
add band=5ghz-a/n/ac frequency=5660 name=CH132
add band=5ghz-a/n/ac frequency=5680 name=CH136
add band=5ghz-a/n/ac frequency=5700 name=CH140
add band=5ghz-a/n/ac frequency=5745 name=CH149
add band=5ghz-a/n/ac frequency=5765 name=CH153
add band=5ghz-a/n/ac frequency=5785 name=CH157
add band=5ghz-a/n/ac frequency=5805 name=CH161
add band=5ghz-a/n/ac frequency=5825 name=CH165
/caps-man security
add authentication-types=wpa-psk,wpa2-psk comment=EnterRealmOfWOOWiFi encryption=tkip \
name=security1 passphrase=EnterRealmOfWOOWiFi
/caps-man configuration
add channel=channel6 country="czech republic" datapath=datapath1 installation=indoor \
mode=ap name=WOO2.4 security=security1 ssid=WOO2.4Staff
add country="czech republic" datapath=datapath1 mode=ap name=WOO5 security=security1 \
ssid=WOO5Staff
add channel=channel11 country="czech republic" datapath=datapath2 datapath.vlan-id=10 \
installation=indoor mode=ap name="WOO2.4 GUEST" ssid=WOO2.4Guest
/caps-man datapath
add bridge=bridge1 name=datapath1
add bridge="GUEST BR" name=datapath2 vlan-id=10
/caps-man interface
add configuration=WOO2.4 disabled=no l2mtu=1600 mac-address=74:4D:28:86:D0:2F \
master-interface=none name=WOOAP4-1 radio-mac=74:4D:28:86:D0:2F radio-name=\
744D2886D02F
add configuration="WOO2.4 GUEST" disabled=no l2mtu=1600 mac-address=76:4D:28:86:D0:2F \
master-interface=WOOAP4-1 name=WOOAP4-1-1 radio-mac=00:00:00:00:00:00 radio-name=\
764D2886D02F
add configuration=WOO5 disabled=no l2mtu=1600 mac-address=74:4D:28:86:D0:30 \
master-interface=none name=WOOAP4-2 radio-mac=74:4D:28:86:D0:30 radio-name=\
744D2886D030
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge1
/caps-man provisioning
add action=create-enabled hw-supported-modes=b,g master-configuration=WOO2.4 name-format=\
identity slave-configurations="WOO2.4 GUEST"
add action=create-enabled hw-supported-modes=ac master-configuration=WOO5 name-format=\
identity
As you can see I’m using configuration WOO5 for AC-capable radios. The network WOO5Staff is created succesfully on the cAP and I can be connected to the internet and LAN, exactly as I wanted.
Problem is that the DATA RATE on the connection is only 54Mbit. When I configure the radio on cAP separately (without CAPsMAN) I’m getting 866Mbit data rate.
Does anyone know where the problem is?
