CAPsMAN and AMSDU together with iOS
Hello!
I have the problem, that all apple devices loose their WiFi connection, if they are not used. I read in several other threads, that reducing the AMSDU values to 4096 solved the problem. How do I change that value if I use CAPsMAN?
BR Holger
Hi
I have the samr question. Help!!!
Did you find a way to configure AMSDU Limit via CAPsMAN?
Unfortunately ( / of course) if AP is managed via CAPsMAN the parameter can’t be configured locally on the AP.
