Hello everyone!
I’m currently testing Mikrotik CAPsMAN. Test topology is in attachment. 1100 is a CAPsMAN two 951 are CAPs.
Configuration I’ve made is a bare minimum for CAPsMAN to work (Configuration name, country, SSID and wpa2-psk security), all the rest is left with default values. RouterOS version is 6.18
For test purposes all devices are located close to each other (about 2 meters).
When I provision the CAPs, both of them choose channel 1 (Frequency 2412), though the manual http://wiki.mikrotik.com/wiki/Manual:CAPsMAN#Master_Configuration_Profiles states that "CAPsMAN will automatically determine the best frequency that is least occupied." and here http://forum.mikrotik.com/t/capsman-auto-frequency/75571/1 Mikrotik employee states that “If all your HomeAPs are near to each other and are added in the CAPsMAN then they will try to use different frequency.”, but none of that actually works for me.
Question1: is there really a feature, that allows APs to choose least occupied an non-overlapping frequencies and how do I activate it?
Question2: Is it possible to assign different channels to CAPs provisioned with the same configuration manually?
Question 3: is roaming currently implemented and how do I activate it for CAPsMAN-CAPs topology?
