Is there a way to create a configuration at Capsman so each cap will create an SSID with its identity?
e.g. cap with identity AP01 when assigned the configuration profile through capsman will create the SSID “AP01” and with the same configuration assigned AP02 will create the SSID “AP02”
(For 50 APs it is difficult to create 50 configurations for each and every one of them.)
Because i would like to get to know the physical possition of each and every one AP without having to physically uninstall the AP to view the S/N or MAC address.
Why you don’t set only identity on APs while you install and use same SSID?
If you use “create enabled” you can see which one is down and in configuration you can use AP identity as cap name.
