Kindly ask your support on my current issue.
Have rb5009+2xcap ax managed by capsman with auto provisioning and working perfect.
Now i bought a cAP Lite, upgraded to last version 7.14.3 and configured the new rules for provisioning in the rb5009.
No capsman is running on the cap lite and there i can only find the package “wireless” to install -and is.
I configure cap on the cap lite on the wifi menu with the discovery interface and a local created datapath and right after the cap lite is in the capsman of rb5009 as remote cap and gets the certificate.
After that i never see the radios from cap lite in capsman neither in cap lite it shows managed by capsman.
If in cap lite i also configure cap in the wireless tables menu, capsman in rb5009 continue to show the cap lite but still no radio and also in the cap lite i see the wifi interface as managed by capsman even if it’s own capsman is not enabled.
Can anyone please help me understand if i do something wrong or if this even not possible?
Thanks in advance.
cAP Lite uses the wireless package and is not supported by the new wifi package (included since 7.12 if memory serves me…)
To manage that device, you would need to install the wireless package on the RB5009 and configure (the old) CAPsMAN. You would have two CAPsMAN’s running (which in itself is not a problem).
Thank you for your reply.
I was confused as i tried to read all in the forum and got the idea that in fact the new wifi-qcom was compatible and able to manage the previous version. And as i have it in the remote aps i was like i made some error on the config…
I am going right now to install the other package on the rb5009 that acts as capsman server and see if all is working
Specially that i just got the second cap lite i ordered!
Ok so what happens:
Installing the "wireless" package disables the "wifi-qcom" one. I do not really know if this impacts anything on the cap ax aps i have, but seems their config is applied and working as before.
Edit: with old wireless package seems AX is not available.
But still i do not see the ap lite radio in the rb5009 wifi radios list and the config i created to provision it is not applied.
Even if the cap lite is saying managed by capsman.
The RB5009 doesn’t need the wifi-qcom driver, as CAPsMAN (new style) is part of the RouterOS package.
If the cAP Lite is the only old wireless driver device, you can (perhaps better) consider configuring it manually instead of being managed through CAPsMAN.
I think i got it. I was confused about all the cAP related thingies like packages, models, drivers, etc…
Yeah now i got it going for the cap lite units and after going to re-enable the cAP AX ones.
Yeah running parallel capsman is the way and seems I finally got it.
