I have configured a wifi with CapsMAN on Hap Ax and Cap Ax. The CAP Ax pick up the configuration as expected, but The Hap AX don’t. It shows managed by CapMAN, the log shows select, connect, joined to the CapsMAN. I tired to add lo interface for testing but the provision not push the configuration to the local CAP
Can sombody help me to find what could be the problem in my configuration
add admin-mac=F4:1E:57:4E:CD:B8 auto-mac=no fast-forward=no name=LAN
set [ find default-name=ether1 ] name=WAN
/interface wifi
# managed by CAPsMAN
set [ find default-name=wifi1 ] configuration.manager=capsman-or-local .mode= ap disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman-or-local .mode= ap disabled=no
/interface wifi channel
add band=2ghz-n disabled=no frequency=2437 name=CH24-6 skip-dfs-channels=all width=20mhz
add band=2ghz-n disabled=no frequency=2412 name=CH24-1 skip-dfs-channels=all width=20mhz
add band=5ghz-ax disabled=no frequency=5220 name=CH50-44 skip-dfs-channels=all width=20/40mhz
add band=5ghz-ax disabled=no frequency=5280 name=CH50-56 skip-dfs-channels=all width=20/40mhz
/interface wifi datapath
add bridge=LAN disabled=no name=datapath1
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no ft=yes ft-over-ds=yes group-encryption=ccmp group-key-update=1h name=TESTSEC
/interface wifi configuration
add channel=CH24-1 country=Hungary datapath=datapath1 disabled=no mode=apname=CF24-1 security=TESTSEC security.ft=yes .ft-over-ds=yes ssid=TEST
add channel=CH24-6 country=Hungary datapath=datapath1 disabled=no mode=ap name=CF24-6 security=TESTSEC ssid=TEST
add channel=CH50-44 country=Hungary datapath=datapath1 disabled=no mode=ap name=CF50-44 security=TESTSEC ssid=TEST
add channel=CH50-56 country=Hungary datapath=datapath1 disabled=no mode=ap name=CF50-56 security=TESTSEC ssid=TEST
add name=dhcp_pool0 ranges=192.168.76.1-192.168.76.200
add address-pool=dhcp_pool0 interface=LAN name=dhcp1
add bridge=LAN interface=ether2
add bridge=LAN interface=ether3
add bridge=LAN interface=ether5
add bridge=LAN interface=ether4
add bridge=LAN interface=wifi1
add bridge=LAN interface=wifi2
/interface wifi cap
set caps-man-addresses=192.168.76.254 certificate=WiFi-CAPsMAN-F41E574ECDB7 discovery-interfaces=LAN enabled=yes lock-to-caps-man=no
/interface wifi capsman
set ca-certificate=WiFi-CAPsMAN-CA-F41E574ECDB7 certificate=WiFi-CAPsMAN-F41E574ECDB7 enabled=yes interfaces=LAN package-path="" require-peer-certificate=yes upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no identity-regexp=CAP1 master-configuration=CF24-1 name-format=CAP-Teszt24 supported-bands=2ghz-n
add action=create-dynamic-enabled common-name-regexp="" disabled=no identity-regexp=CAP1 master-configuration=CF50-44 name-format=CAP-Teszt50 supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no identity-regexp=Router master-configuration=CF50-56 name-format=Router-Test50
add action=create-dynamic-enabled disabled=no identity-regexp=Router master-configuration=CF24-6 name-format=Router-Test24
add address=192.168.76.254/24 interface=LAN network=192.168.76.0
/ip dhcp-client
add interface=WAN
add address=192.168.76.0/24 gateway=192.168.76.254
add action=masquerade chain=srcnat out-interface=WAN src-address=192.168.76.0/24
/ip ipsec profile
/system clock
set time-zone-name=Europe/Budapest
/system identity
set name=Router
/system note
set show-at-login=no
/system ntp client
set enabled=yes mode=manycast
/system ntp client servers
add address=192.168.200.254
