How can I have mixed WiFi protocols on on the same CapsMan profile?
I have several APs with 2 Ghz N standard, but would need to add one access point with 5Ghz for one connection. How to do that? I see I can select only one channel per configuration, and no way to select one for mixed AP network.
Just to check; I make two configurations with same settings, one for 2Ghz and one for 5GHz?
(Maybe it is a stupid Q, but should I apply those manually, or it will work automatically?)
The Band/Frequency will be different in both configurations
The Hw. Supported Modes (you can use gn for 2.4GHz or ac for 5GHz) and Master Configuration will be different in both provisionings
Based on those provisioning rules will CAPsMAN send correct configuration to CAP interface.
