CAPsMAN and dynamic interface names
Is there any way to have CAPsMAN controlled interfaces with static interface names?
It’s difficult to monitor wireless traffic of wireless interfaces with snmp because if.index changes every time an CAPS-AP reconnects to CAPsMAN… :-/
We already have such option, from:
http://wiki.mikrotik.com/wiki/Manual:CAPs_Manager#Radio_Provisioning
create-disabled - create disabled static interfaces for radio. I.e., the interfaces will be bound to the radio, but the radio will not be operational until the interface is manually enabled;
create-enabled - create enabled static interfaces. I.e., the interfaces will be bound to the radio and the radio will be operational;
create-dynamic-enabled - create enabled dynamic interfaces. I.e., the interfaces will be bound to the radio, and the radio will be operational;
none - do nothing, leaves radio in non-provisioned state;
and the difference between these settings is…?
Static/dynamic ..here is the difference
Static interfaces will not be auto provisioned again (only manual intervention)
Dynamic ones are provisioned at every boot/connection
