CAPsMAN and group ciphers
Can somebody please help me understand why the security profiles for standalone wireless AP configuration allows group ciphers to be “multiple choice” (both tkip and aes-ccm) while CAPsMAN security profiles only allow you to specify one or the other?
I will note that in the RouterOS Wiki documentation for Security Profiles, for unicast-ciphers, it says that “access point advertises that it supports specified ciphers”, while for group-ciphers, it says that “access point advertises ONE of these ciphers” (emphasis mine), so that is interesting. If the access point only advertises one cipher for broadcast and multicast, why does it give you the ability to check both? Is the “multiple choice” feature intended for stations and not APs (so that a station can associate to either kind of AP using a single profile)? If so, then if you check both tkip and aes-ccm for a security profile that you apply to an AP interface, which cipher type will the AP advertise and use?
I would not be surprised to learn that it is only possible to use one cipher type or the other for broadcast and multicast traffic, otherwise an AP would have to transmit every broadcast or multicast packet TWICE. But nothing explains why the standard interface ALLOWS you to select both for group-cipher while CAPsMAN forces you to choose one or the other, nor does anything explain what the defined behavior of a standalone AP is when both are checked. This really should be spelled out more explicitly in the documentation than it is (that is to say, not at all).
Thanks,
– Nathan
For the benefit of others who would also like to know the answer to this, I got the following very helpful reply from Uldis via support e-mail: “In case of AP you can only have one group cipher so in case you have specified tkip and aes, the strongest will be used and it will be aes.”
So for security profiles outside of CAPsMAN, if you check both TKIP and AES, and you apply that security profile to a wireless interface in ap-bridge mode, it will use AES for the group/multicast cipher. Uldis also confirmed for me that if you apply that same security profile to a wireless interface in station mode, having both checked means that it will try to use whichever one the AP wants to use.
Thanks,
– Nathan
