Capsman and his own CAP issue
hello my friends
I am new here.
I setup capsman on RB941, and my problème is that I can not manage the own wireless of the capsman, I can see only the differents outside CAPs.
I need to use the own wireless of CAPsman, else I need to get another AP.
in the first I remove all firewall rule, and no succes
I’ve try to add firewall rules and accept trafic from 127.0.0.1 but don’t work.
have you some Idea?
I use 3 RB941, one of them is capsman and two other CAP.
thank you
You can try latest ROS beta which likely do not need below workaround anymore (I did not test this yet):
*) capsman - always accept connections from loopback address;
Otherwise this should fix it:
/capsman manager interface
set [find default=yes] forbid=no
add forbid=yes interface=(here put interface which should not listen, e.g. WAN)
And for firewall use this:
add action=accept chain=input dst-address-type=local src-address-type=local
If this does not help then post here from your CAPsMAN:
interface wireless cap print
