I have setup a test lab with 2 devices.
2 RB 951G-2HnD
1 as CAPsMAN and one as CAP.
If I connect a wireless device I will not get an IP address.
In the DHCP server on the CAPsMAN router I see it offers an IP but the device will not get it.
What is wrong in the config?
Both configs are here below.
CAPsMAN Config:
jan/02/1970 20:35:35 by RouterOS 6.41.3
software id = M8LD-6QCX
model = 951G-2HnD
serial number = 3E2D0135AE85
/caps-man channel
add band=5ghz-onlyac comment=“Only 5GHZ AC” control-channel-width=20mhz
extension-channel=eeeC name=“5GHZ Only AC”
add band=2ghz-onlyn comment=“Only 2GHZ N” control-channel-width=20mhz
extension-channel=eC name=“2GHZ Only N”
add name=BRIDGE vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface vlan
add interface=BRIDGE name=VLAN_LAN_CAMERA vlan-id=17
add interface=BRIDGE name=VLAN_LAN_DATA vlan-id=10
add interface=BRIDGE name=VLAN_LAN_MGMT vlan-id=9
add interface=BRIDGE name=VLAN_LAN_SERVER vlan-id=900
add interface=BRIDGE name=VLAN_WLAN_DATA vlan-id=12
add interface=BRIDGE name=VLAN_WLAN_GUEST vlan-id=14
add interface=BRIDGE name=VLAN_WLAN_IOT vlan-id=15
add interface=BRIDGE name=VLAN_WLAN_SP vlan-id=19
/caps-man datapath
add bridge=BRIDGE local-forwarding=yes name=datapath_WLAN_DATA vlan-id=12
vlan-mode=use-tag
add bridge=BRIDGE local-forwarding=yes name=datapath_WLAN_GUEST vlan-id=14
vlan-mode=use-tag
add bridge=BRIDGE local-forwarding=yes name=datapath_WLAN_IOT vlan-id=15
vlan-mode=use-tag
add bridge=BRIDGE local-forwarding=yes name=datapath_WLAN_SP vlan-id=19
vlan-mode=use-tag
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm
name=sec_WLAN_DATA
name=sec_WLAN_GUEST
name=sec_WLAN_IOT
name=sec_WLAN_SP
/caps-man configuration
add channel=“5GHZ Only AC” country=netherlands datapath=datapath_WLAN_DATA
mode=ap name=“conf WLAN_DATA 5GHZ AC” security=sec_WLAN_DATA ssid=
WLAN_DATA
add channel=“5GHZ Only AC” country=netherlands datapath=datapath_WLAN_GUEST
mode=ap name=“conf WLAN_GUEST 5GHZ AC” security=sec_WLAN_GUEST ssid=
WLAN_GUEST
add channel=“5GHZ Only AC” country=netherlands datapath=datapath_WLAN_IOT
mode=ap name=“conf WLAN_IOT 5GHZ AC” security=sec_WLAN_IOT ssid=WLAN_IOT
add channel=“5GHZ Only AC” country=netherlands datapath=datapath_WLAN_SP
mode=ap name=“conf WLAN_SP 5GHZ AC” security=sec_WLAN_SP ssid=WLAN_SP1
add channel=“2GHZ Only N” country=netherlands datapath=datapath_WLAN_DATA
mode=ap name=“conf WLAN_DATA 2GHZ N” security=sec_WLAN_DATA ssid=
WLAN_DATA
add channel=“2GHZ Only N” country=netherlands datapath=datapath_WLAN_GUEST
mode=ap name=“conf WLAN_GUEST 2GHZ N” security=sec_WLAN_GUEST ssid=
WLAN_GUEST
add channel=“2GHZ Only N” country=netherlands datapath=datapath_WLAN_IOT
mode=ap name=“conf WLAN_IOT 2GHZ N” security=sec_WLAN_IOT ssid=LAN_IOT
add channel=“2GHZ Only N” country=netherlands datapath=datapath_WLAN_SP mode=
ap name=“conf WLAN_SP 2GHZ N” security=sec_WLAN_SP ssid=WLAN_SP1
WLAN_DATA
add disabled=no interface=VLAN_LAN_MGMT lease-time=1w name=DHCP_LAN_MGMT
add disabled=no interface=VLAN_LAN_SERVER lease-time=1w name=DHCP_LAN_SERVER
/ip hotspot profile
add hotspot-address=172.16.3.1 name=WLAN_GUEST use-radius=yes
add name=POOL_LAN_DATA ranges=172.16.1.100-172.16.1.200
add name=POOL_WLAN_DATA ranges=172.16.2.100-172.16.2.200
add name=POOL_WLAN_GUEST ranges=172.16.3.100-172.16.3.200
add name=POOL_WLAN_IOT ranges=172.16.4.10-172.16.4.60
add name=POOL_LAN_CAMERA ranges=172.16.5.10-172.16.5.120
add name=POOL_WLAN_SP ranges=172.16.6.100-172.16.6.200
add name=POOL_LAN_SERVER ranges=172.16.0.130-172.16.0.157
add name=POOL_LAN_VPN ranges=172.16.0.161-172.16.0.190
add address-pool=POOL_LAN_DATA disabled=no interface=VLAN_LAN_DATA
lease-time=1w name=DHCP_LAN_DATA
add address-pool=POOL_WLAN_DATA disabled=no interface=VLAN_WLAN_DATA name=
DHCP_WLAN_DATA
add address-pool=POOL_WLAN_GUEST disabled=no interface=VLAN_WLAN_GUEST name=
DHCP_WLAN_GUEST
add address-pool=POOL_WLAN_IOT disabled=no interface=VLAN_WLAN_IOT
lease-time=1w name=DHCP_WLAN_IOT
add address-pool=POOL_LAN_CAMERA disabled=no interface=VLAN_LAN_CAMERA
lease-time=1w name=DHCP_LAN_CAMERA
add address-pool=POOL_WLAN_SP disabled=no interface=VLAN_WLAN_SP lease-time=
1w name=DHCP_WLAN_SP
/ip hotspot
HOTSPOT-WLAN_GUEST profile=WLAN_GUEST
/snmp community
set [ find default=yes ] addresses=172.16.0.60/32 read-access=no
add addresses=172.16.0.60/32 authentication-protocol=SHA1
encryption-protocol=AES name=SNMPuser1 security=private
/system logging action
set 3 remote=172.16.0.60
/caps-man access-list
add action=accept comment=“Allow all connections on WLAN_GUEST” signal-range=
-80..80 ssid-regexp=WLAN_GUEST
add comment=“PC030 Ronald Verheij” mac-address=A0:88:B4:13:14:7C
signal-range=-80..80 ssid-regexp=WLAN_DATA
add comment=“PC030 Ronald Verheij WiFi AC” mac-address=D4:6E:0E:04:7C:A3
add comment=“PC036 Henk Verheij” mac-address=00:26:C7:25:4B:B0 signal-range=
add comment=“PC040 Siska Verheij” mac-address=18:3D:A2:49:31:E0 signal-range=
add comment=“PC042 Dirk Vlot Dell Latutude E5510” mac-address=
C0:CB:38:44:B2:0E signal-range=-80..80 ssid-regexp=WLAN_DATA
add comment=“PC044 Dirk Vlot Desktop” mac-address=C0:4A:00:1A:85:DE
add comment=“PC050 Jacqueline Verheij” mac-address=C0:CB:38:7C:82:60
add comment=“PC053 Arno Meijboom” mac-address=20:10:7A:21:8C:81 signal-range=
add comment=“MACBOOK Pro Angela” mac-address=B8:8D:12:34:AC:9C signal-range=
add comment=“PR001Epson Expression Premium XP720” mac-address=
64:EB:8C:14:35:3A signal-range=-80..80 ssid-regexp=LAN_MFP
add comment=“GC002 Wii002 Jacqueline Verheij” mac-address=E8:4E:CE:60:05:AF
signal-range=-80..80 ssid-regexp=LAN_GAME
add comment=“MMB001 TV001 Ring 393” mac-address=5C:DA:D4:3A:39:EC
signal-range=-80..80 ssid-regexp=LAN_TVMM
add comment=“MMB002 XBMC001 Zotax Ring 393 Beneden” mac-address=
00:01:2E:40:25:6C signal-range=-80..80 ssid-regexp=LAN_TVMM
add comment=“MMB003XBMC002 Ring 393 Boven” mac-address=00:0F:60:00:D6:75
add comment=“MMB004 P1 Monitor” mac-address=00:0F:60:00:D6:75 signal-range=
add comment=“MMB005 Raspberry Pi3” mac-address=B8:27:EB:0E:46:C1
add comment=“SPK01 Philips SW700m/12” mac-address=00:22:61:D6:BF:44
add comment=“MOB002 Ronald Verheij Samsung S3” mac-address=34:23:BA:4A:2A:8D
signal-range=-80..80 ssid-regexp=WLAN_SP
add comment=“MOB004 Henk Verheij BB” mac-address=3C:73:37:7A:38:49
add comment=“MOB009 Arno Meijboom” mac-address=88:E8:7F:A1:1A:83
add comment=“MOB014 Ronald Verheij Huawei p9 Lite” mac-address=
E0:A3:AC:18:79:D0 signal-range=-80..80 ssid-regexp=WLAN_SP
add comment=“MOB016 Angela” mac-address=78:D7:5F:DD:55:E2 signal-range=
add comment=“MOB017 Elly Vlot Samsung A5 2017” mac-address=E0:AA:96:D8:A9:DE
add comment=“MOB018 Siska Verheij Huawei P9 lite” mac-address=
A4:71:74:AB:44:8A signal-range=-80..80 ssid-regexp=WLAN_SP
add comment=“MOB019 Dirk Vlot Wiko” mac-address=BC:44:34:48:4D:03
add comment=“TAB001 Jacqueline Verheij Samsung” mac-address=8C:77:12:5D:78:86
add comment=“TAB005 Dirk Vlot Samsung” mac-address=34:AA:8B:02:74:31
add comment=“TAB006 Siska Verheij Kinder tab” mac-address=18:FE:34:80:95:87
add comment=“TAB009 Siska Verheij” mac-address=A8:9F:BA:9A:9B:E7
add comment=“TAB010 Ronald Verheij Shield K1” mac-address=00:04:4B:60:F7:70
add comment=“TAB011 Jacqueline Verheij Samsung S2” mac-address=
F4:42:8F:BB:8C:DC signal-range=-80..80 ssid-regexp=WLAN_SP
add comment=“TOON001 Arno Meijboom” mac-address=28:C2:DD:E4:30:AB
add comment=“TOON002 Fam Vlot” mac-address=74:C6:3B:9F:77:BF signal-range=
add action=accept comment=“Ronald Verheij Huawei P10 lite” disabled=no
mac-address=0C:8F:FF:FB:11:1E signal-range=-120..120 ssid-regexp=WLAN_SP
add action=reject comment=“Block all other requests” interface=all
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled comment=“2 GHZ Only N” hw-supported-modes=
gn master-configuration=“conf WLAN_DATA 2GHZ N” name-format=identity
slave-configurations=
“conf WLAN_GUEST 2GHZ N,conf WLAN_IOT 2GHZ N,conf WLAN_SP 2GHZ N”
add action=create-dynamic-enabled comment=“2 GHZ Only AC” hw-supported-modes=
ac master-configuration=“conf WLAN_DATA 5GHZ AC” name-format=identity
“conf WLAN_GUEST 5GHZ AC,conf WLAN_IOT 5GHZ AC,conf WLAN_SP 5GHZ AC”
add bridge=BRIDGE interface=ether1
add bridge=BRIDGE interface=ether5
/interface bridge vlan
add bridge=BRIDGE tagged=ether1,ether5,BRIDGE vlan-ids=9,10,12,14,15,19,900
add address=172.16.0.1/25 interface=VLAN_LAN_MGMT network=172.16.0.0
add address=172.16.1.1/24 interface=VLAN_LAN_DATA network=172.16.1.0
add address=172.16.2.1/24 interface=VLAN_WLAN_DATA network=172.16.2.0
add address=172.16.4.1/26 interface=VLAN_WLAN_IOT network=172.16.4.0
add address=172.16.6.1/24 interface=VLAN_WLAN_SP network=172.16.6.0
add address=172.16.0.129/27 interface=VLAN_LAN_SERVER network=172.16.0.128
add address=172.16.3.1/24 interface=VLAN_WLAN_GUEST network=172.16.3.0
add address=172.16.5.1/25 interface=VLAN_LAN_CAMERA network=172.16.5.0
add address=172.16.0.0/25 dns-server=172.16.0.130,172.16.0.131 gateway=
172.16.0.1 netmask=25
add address=172.16.0.128/27 dns-server=172.16.0.130,172.16.0.131 gateway=
172.16.0.129 netmask=27
add address=172.16.1.0/24 dns-server=172.16.0.130,172.16.0.131 gateway=
172.16.1.1 netmask=24
add address=172.16.2.0/24 dns-server=172.16.0.130,172.16.0.131 gateway=
172.16.2.1 netmask=24
add address=172.16.3.0/24 dns-server=8.8.8.8 gateway=172.16.3.1 netmask=24
add address=172.16.4.0/25 dns-server=172.16.0.130,172.16.0.131 gateway=
172.16.4.1 netmask=25
add address=172.16.5.0/25 dns-server=172.16.0.130,172.16.0.131 gateway=
172.16.1.1 netmask=25
add address=172.16.6.0/24 dns-server=172.16.0.130,172.16.0.131 gateway=
172.16.6.1 netmask=24
set allow-remote-requests=yes servers=172.16.0.130,172.16.0.131
add action=passthrough chain=unused-hs-chain comment=
“place hotspot rules here” disabled=yes
/ip hotspot user
add name=admin
add comment=“Sonicwall TZ215 Ring 393” distance=1 gateway=172.16.0.125
add comment=“R02 Mikrotik x86 Ring 225” distance=2 gateway=172.16.0.126
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=172.16.0.0/21
set api disabled=yes
set api-ssl disabled=yes
/snmp
set contact=ronald.verheij@skiffkick.nl.nl enabled=yes engine-id=SNMPuser1
location=“Ring 393, Pernis, The Netherlands” trap-community=SNMPuser1
trap-generators=interfaces trap-interfaces=all trap-target=172.16.0.60
trap-version=3
/system clock
set time-zone-name=Europe/Amsterdam
/system identity
set name=R01
/system logging
add action=remote topics=warning
add action=remote topics=info
add action=remote topics=critical
add action=remote topics=error
add action=remote topics=wireless
add action=remote topics=hotspot
/system ntp client
set enabled=yes primary-ntp=172.16.0.130 secondary-ntp=172.16.0.131
CAP Config:
jan/02/1970 19:37:49 by RouterOS 6.41.3
software id = R9VT-LA3C
model = 951G-2HnD
serial number = 642E051FF569
/interface wireless
managed by CAPsMAN
channel: 2447/20-eC/gn(20dBm), SSID: WLAN_DATA, local forwarding
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
add mac-address=E6:8D:8C:E6:F9:BB master-interface=wlan1 mode=station name=
wlan8
add mac-address=E6:8D:8C:E6:F9:BC master-interface=wlan1 mode=station name=
wlan9
add mac-address=E6:8D:8C:E6:F9:BD master-interface=wlan1 mode=station name=
wlan10
/interface vlan
/snmp community
set 3 remote=172.16.0.20
add bridge=BRIDGE tagged=ether1,BRIDGE vlan-ids=9,10,12,14,15,19
/interface wireless cap
set bridge=BRIDGE caps-man-addresses=172.16.0.1 certificate=request
discovery-interfaces=ether1 enabled=yes interfaces=wlan1
add address=172.16.0.13/25 interface=VLAN_LAN_MGMT network=172.16.0.0
set servers=172.16.0.130,172.16.0.131
add distance=1 dst-address=172.16.0.0/21 gateway=172.16.0.1
/ip service
set www address=172.16.0.0/21 disabled=yes
/snmp
location=“Ring 393, Pernis, Zolder” trap-community=SNMPuser1
trap-version=3
/system clock
/system identity
set name=“SW12 - Ring 227”
/system logging
/system ntp client
CAPsMAN.rsc (12.6 KB)
CAP.rsc (2.53 KB)
