CAPsMAN and revoked cert
I revoked a certificate which was gererated by CAPsMAN. But I am not able to delete it. When I let CAPsMAN create a new CA an cert, the old revoked is used. I can bind a WLAN-AP but after some minutes, the connection gets lost because of cert mismatch. How can I remove all certs and CAs without reset the router?
Issued certificates on RouterOS can be removed only together with CA. You cannot remove only revoked certs.
The CA is removed already
If you remove CA then all issued certificates using that CA is automatically removed.
