I have hotel project with 1 x CRS326-24G and 24 x wsAP ac, and I want to install 1 wsAP in each room plus IP Telephone.
I did that using VLANs and everything is OK.
But can I use CAPsman feature to distribute Wireless configuration plus Telephony VLANs configuration? it would simplify the job.
Did the same already.
It’s a pity though.
Stuff on that site is not so bad, if only he did not provide that much links over there (when I clicked the button, it was 16 on 31 posts, so over 50%).
And anav, it’s each time another post
It’s the digging up even years old posts, just to post the link, that I don’t like. If it’s something current and the link is helpful, no problem with that, OP can appreciate it.
The articles provided by @lfoerster in the link are really good covering a wide range of useful scenarios that are not found elsewhere. Most actually deserves a place in “Useful user articles”
EDIT:
Supplementary articles can be found far down under “Related links”.
Not reply to each and every thread from several weeks or months old.
I saw some responses which were really relevant, no problem at all there.
A short explanation and then redirecting for more info to the other place.
But there were also posts from months old where all he did was post the link as in “Go see here”. That’s adding to suspicious behavior.
Again, I did some brief checking on that site, there is good info there (and thank God for Google Translate, I understand German but not at that level ).
