CapsMan and X86 6.37 release
Hi!
I got a PC running the 6.36.3 version of routerOS. I´m running CapsMan on it, but the router itself has no wireless interface installed.
When I trying to upgrade to 6.37 the wireless package don´t get active, it installs, but stays passive/disabled. Is the 6.37 wireless package depending on a present wireless interface to run?
/SA0BJW
I’m running CapsMan on 6.37 on my RB450G (no wireless) and it works fine. It might be a x86 specific issue, or it might just take a reboot. I think mine took a reboot or two before it showed as active.
No.. I can´t get the wireless package to run on my x86 6.37 machine.. Have tried to reboot a couple of times, but it still stay:s disabled. Have to downgrade to 6.36.6 to get the package to run.
WIll try to install a wireless NIC and test if that works..
/SA0BJW
Since the release of 6.37.1 the problem has been solved!
