Capsman anf firmware 6.43.4
Hi, all.
After upgrading firmware to 6.43.4 Capsman controller can’t get parametres from itself.
Wireless Tables->Wifi Interfaces I see – managed by CAPsMAN and no any parametres.
In filter rule
add action=accept chain=output dst-address=127.0.0.1 port=5246,5247 protocol=
udp src-address=127.0.0.1
add action=accept chain=input dst-address=127.0.0.1 port=5246,5247 protocol=udp
In wifi interfaces
/interface wireless cap
set bridge=bridge-local caps-man-addresses=127.0.0.1 discovery-interfaces=
bridge-local enabled=yes interfaces=wlan1
In log
13:26:36 caps,info CAP failed to join MikroTik (::ffff:192.168.0.1:5246)
13:26:43 caps,info CAP selected CAPsMAN MikroTik (::ffff:192.168.0.1:5246)
13:27:03 caps,info CAP connect to MikroTik (::ffff:192.168.0.1:5246) failed: timeout
Before upgrading from 6.42.6 to 6.43.4 i have no such problem with controller. It works like cap and correctly recieved all parametres from itself
Is it problem in 6.43.4 or somewhere else?
It’s highly unlikely that your dst-address=127.0.0.1 rule will match traffic to 192.168.0.1:5246. Try to use a dst-address-type=local src-address-type=local rule like documented at https://wiki.mikrotik.com/wiki/Manual:Simple_CAPsMAN_setup#CAP_in_CAPsMAN
