- it would be nice if u can set antenna gain to caps from capsmanager. i have to setup antenna gain to 40 caps one by one because i need less transmit power.
- would be nice to apply commands from capsman to caps like reboot, beep, telnet etc
+1 for remote commands…
I need reboot CAP’s remotely.
Thanks in advance.
Why can’t you simply specify the tx-power instead of tweaking the antenna gain in this case? You can control tx-power from the CAPsMAN (that is a property of channel).
Yet another RoMON?
