Ros 6.49.15
I setup a bunch of wap-ac controlled by Capsman with a very little config:
Mode (ap)
SSID
Country
Datapath
Security
No channel configured.
Once system starts, what’s the philosophy behind frequency selection ?
Having different AP’s with different frequency, is it random or is frequency analyzed and then set ? (per AP ?)
To force a dual-band AP to use a single band, is it enough to configure just that band into Channels section ? (and make AP to load that CFG) , because doing so i seems both bands are still used…
Nobody seems to know for sure but most likely there is a scan going on to determine the least used frequency.
If you have multiple devices all starting up at the same time, it can happen they arrive at the same frequency.
I never use auto, I want to decide which frequency gets used.
Provisioning rules determine which radio gets what config.
If there is a specific radio you don’t want to use, a couple of options:
don’t provision it
provision it as none or disabled (my preference since you can still control things from capsman controller)
simply disable that radio so it doesn’t participate at all
“Nobody seems to know” is a little unsettling…but yes for few arguments (not so few) you would expect someone of Mikrotik staff at least sometimes comes out and say “it works this way: bla bla bla”
I use provisioning by Identity Regexp so when AP identity matches it uses cfgX
On cfgX I declare a channel like this:
/caps-man channel
add band=2ghz-b/g/n name=2g4
but 5GHz band seems to be used anyway…
Am I wrong on something ?
Well... I supposed declaring the only band it behaves like in normal AP choosing band and leaving the frequency=AUTO
And I thought as well , declaring a 2.4GHz band and not the 5 GHz one would shut this last one.
Maybe I'm wrong...... in this case I'm looking for a Capsman provisioning config capable of shutting down the desired band
Or better, have a Capsman provisioning config capable of setup a SSID per radio band, i.e.:
for AP named AP01 use 2.4GHz radio with SSID MY2G4WIFI and the 5GHz radio with SSID MY5GWIFI, any idea ?
