Capsman AP's upgrade failed because of missing wireless-cm2 package ?
How to upgrade AP’s automaticaly over Capsman when missing Wireless-cm2 files in new version ROS ?
There is error in log, because of missing file…
The latest version only has one package named wireless.
Think the best option will be to manually upgrade all of them. Any future upgrades should be able to work
you can upload the wireless package to the CAPsMAN directory where are the upgrade packages stored and manually rename the wireless package to wireless-cm2 and the upgrade should work without problem.
