Capsman auto on Groove 52 ac
I have wAp ac with 2.4 and 5G configured with capsman with auto freq.
I put a new Groove 52 ac. This device have 1 wifi with 2.4 or 5G. My capsman put AUTO in 5Ghz on Groove 52 ac and I want to 2.4 AUTO as first configuration.
How can configure that device with AUTO freq in 2.4 Ghz ?
Best Regards,
Hi There
hoping I correctly understood your needings …
one way is to define from CAPsMAN->Configurations tab a new configuration where you specify the band you want. Then you apply to your controlledAp that configuration , clicking again from CAPsMAN choose the wanted Interface double click on it and change in Wireless tab the used configuration
hoping that helps
I know that, but I want to set AUTO freq.
Provision the configuration with B/G/N band setting and then it will choose the frequency from 2.4ghz
indeed I suggested to change the Band not channel frequencies
I try but just in 5G on auto band.
If i put manual freq work. With auto freq in 2.4 NOT working.
Regards,
