Hi MikroTik,
Just request if possible to auto select un-used channel. by scanning the available channel before enable the CAP.
maybe in the future CAPsMAN can check the channels that already used by registered CAP and select any other available channel for the Next CAP.
and then if there is no available channels, CAPsMAN can do background scan to arrange auto Chanel / frequency utilization for Registered CAP.
Hahah aniway i confuse my self. dont mind it just request,
because when i use CAPsMAN, sometimes the CAP use the same frequency, even when im not select any single frequency.
Thanks All.
