Good day.
I would like to ask a question about the operation of the frequency selection mechanism in the capsman. I want to ensure that the access points choose different frequencies for themselves depending on the environment in the place where they are installed. To do this, I do the following setup:
/caps-man channel add band=2ghz-g/n frequency=2412,2437,2462 name="channels 2.4" reselect-interval=12h
or
/caps-man channel add band=2ghz-g/n name="channels 2.4" reselect-interval=12h
I expect the APs to choose different frequencies for themselves. Instead, all access points choose one frequency for themselves.
For 5 GHz I also use extension-channel = XXXX and all APs choose the same configuration.
Is this behavior normal or a bug?
Are there any beautiful solutions, instead of attaching a separate channel setting to each point?
