CapsMan: avoid channel
In a setup with multiple wAP ac setup as CAPs administrated from CapsMan, where both the 5ghz and 2ghz radios are provided with the same configuration, what is the easiest way to avoid that a single CAP select a specific channel?
The current issue is that one Caps 2ghz tend to select the 2427MHz channel, and this frequency is sometimes highly disturbed by other electrical appliances (running for a few minutes every few hours). I’d like to tell this particular Cap to never select this frequency, while leaving this frequency available to all the other Caps, and preferably still let all caps share other configuration. Whats the easiest way to do this?
In CAPsMAN create Channels and then use those to assign the Channel in the CAP Interface section.
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2412 name=F-ch1-2412
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2437 name=F-ch6-2437
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled frequency=2462 name=F-ch11-2462
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5180 name=F-ch36-5180
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5200 name=F-ch40-5200
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5220 name=F-ch44-5220
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5240 name=F-ch48-5240
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5745 name=F-ch149-5745
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5765 name=F-ch153-5765
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5785 name=F-ch175-5785
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5805 name=F-ch161-5805
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=disabled frequency=5825 name=F-ch165-5825
/caps-man interface
add channel=F-ch1-2412 configuration=Office-VLAN10 disabled=no l2mtu=1600 mac-address=CC:2D:E0:XX:XX:XX master-interface=none name=CAPAC-1 radio-mac=CC:2D:E0:XX:XX:XX radio-name=CC2DE0XXXXXX
add channel=F-ch11-2462 configuration=Office-VLAN10 disabled=no l2mtu=1600 mac-address=CC:2D:E0:YY:YY:YY master-interface=none name=CAPAC-2 radio-mac=CC:2D:E0:YY:YY:YY radio-name=CC2DE0YYYYYY
