CAPsMAN bandwidth problem
Hy!
I have the following configuration:
-1 (Non-Mikrotik router, which has internet and DHCP)
-1 CRS112-8P-4S-IN switch (it is functional with switch and CAPsMAN)
-1 wAP AC
The switch has a bridge which is include the all ethernet ports. The switch directly connected to the router and the AP connect to the switch. When I configured the CAPsMAN and the AP connect to the switch CAPsMAN succesfully, I can connect 5GHz to wifi and using internet. But when I run BTest application to test bandwidth, the bandwidth is about 50-50Mbps, but the data rate is 866Mbps. Why cannot reach the maximum bandwidth?
/caps-man channel
add band=2ghz-b/g/n frequency=2412 name=CH1
add band=5ghz-a/n/ac frequency=5180 name=CH36
/caps-man configuration
add guard-interval=any mode=ap name=cfg1_2GHz rx-chains=0,1,2,3 ssid=Teszt_2GHz tx-chains=0,1,2,3
add guard-interval=any mode=ap name=cfg2_5GHz rx-chains=0,1,2,3 ssid=Teszt_5GHz tx-chains=0,1,2,3
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=security1 passphrase=123.Pass
/caps-man datapath
add bridge=bridge1 name=datapath1
/caps-man interface
add channel=CH1 configuration=cfg1_2GHz datapath=datapath1 disabled=no l2mtu=1600 mac-address=B8:69:F4:F8:3E:4E master-interface=none name=AP2_2GHz radio-mac=\
    B8:69:F4:F8:3E:4E radio-name=B869F4F83E4E security=security1
add channel=CH36 configuration=cfg2_5GHz datapath=datapath1 disabled=no l2mtu=1600 mac-address=B8:69:F4:F8:3E:4D master-interface=none name=AP2_5GHz radio-mac=\
    B8:69:F4:F8:3E:4D radio-name=B869F4F83E4D security=security1
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg1_2GHz
Thank You!
I was having similar issues… Hope someone has some answers as been crickets!
With “Local Forwarding” performance is OK and close to wire speeds with AC (depending on AP). I’m finding the CAP AC’s to perform worse than the wAP AC’s. (different wireless chipset).
But with “Client to Client forwarding” enabled, performance is crushed and similar results your experiencing.
