Hello all,
I’ve first used of CAPsMAN and want to know of Wireless channel.
I’ve configured from wiki CAPsMAN and 3 AP, it works great, configuration was sent.
When I,ve configured the AP channel manually, I choosing “auto” or another channel on next AP, but in CAPsMAN there is 1 working channel on all APs in the same time.
Q: Is this configuration is correct? Is it possible to install 3 AP in the same room with the same channel? What about interference on the same channel?
Is the CAPSMAN take control of WiFi communicaton in the Air or only sending config to APs once?
Thanks in advance
