Capsman beginner help
Can anyone help me with setting up capsman?
I have a hapax3 running latest stable OS.
I have ordered a cap AC to use as an extra AP.
Here is my current wifi config, how would I convert this into a capsman config?
I don’t seem to have options for enabling a capsman server? I have the wifiqcom package, do I need wifiwave2 instead?
/interface/wifi> print detail
Flags: M - master; D - dynamic; B - bound; X - disabled, I - inactive, R - running
0 M B default-name=“wifi1” name=“wifi1” l2mtu=1560 mac-address=D4:01:C3:56:FA:10 arp-timeout=auto radio-mac=D4:01:C3:56:FA:10
configuration.mode=ap .ssid=“XXXXXX” .country=United Kingdom
security.authentication-types=wpa2-psk,wpa3-psk .passphrase=“xxxxxxxxxx” .connect-priority=0
channel.band=5ghz-ax .width=20/40/80mhz .skip-dfs-channels=10min-cac
1 M B default-name=“wifi2” name=“wifi2” l2mtu=1560 mac-address=D4:01:C3:56:FA:11 arp-timeout=auto radio-mac=D4:01:C3:56:FA:11
configuration.mode=ap .ssid=“XXXXXXXX” .country=United Kingdom
security.authentication-types=wpa2-psk,wpa3-psk .passphrase=“XXXXXXXXX” .connect-priority=0
channel.band=2ghz-ax .width=20/40mhz .skip-dfs-channels=10min-cac
[klittle@solingen_router] /interface/wifi/radio> print detail
Flags: L - local
0 L radio-mac=D4:01:C3:56:FA:10 tx-chains=0,1 rx-chains=0,1 bands=5ghz-a:20mhz,5ghz-n:20mhz,20/40mhz,5ghz-ac:20mhz,20/40mhz,20/40/80mhz,5ghz-ax:20mhz,20/40mhz,20/40/80mhz
ciphers=tkip,ccmp,gcmp,ccmp-256,gcmp-256,cmac,gmac,cmac-256,gmac-256 countries=all
5g-channels=5180,5200,5220,5240,5260,5280,5300,5320,5500,5520,5540,5560,5580,5600,5620,5640,5660,5680,5700,5720,5745,5765,5785,5805,5825 max-vlans=128 max-interfaces=16
max-station-interfaces=3 max-peers=512 hw-type=“QCA6018” hw-caps=sniffer,qos-classifier-dscp interface=wifi1 current-country=United Kingdom
current-channels=5180/a,5180/n,5180/n/Ce,5180/ac,5180/ac/Ce,5180/ac/Ceee,5180/ax,5180/ax/Ce,5180/ax/Ceee,5200/a,5200/n,5200/n/eC,5200/ac,5200/ac/eC,5200/ac/eCee,5200/ax,5200/ax/eC,
5200/ax/eCee,5220/a,5220/n,5220/n/Ce,5220/ac,5220/ac/Ce,5220/ac/eeCe,5220/ax,5220/ax/Ce,5220/ax/eeCe,5240/a,5240/n,5240/n/eC,5240/ac,5240/ac/eC,5240/ac/eeeC,5240/ax,
5240/ax/eC,5240/ax/eeeC,5260/a,5260/n,5260/n/Ce,5260/ac,5260/ac/Ce,5260/ac/Ceee,5260/ax,5260/ax/Ce,5260/ax/Ceee,5280/a,5280/n,5280/n/eC,5280/ac,5280/ac/eC,5280/ac/eCee,
5280/ax,5280/ax/eC,5280/ax/eCee,5300/a,5300/n,5300/n/Ce,5300/ac,5300/ac/Ce,5300/ac/eeCe,5300/ax,5300/ax/Ce,5300/ax/eeCe,5320/a,5320/n,5320/n/eC,5320/ac,5320/ac/eC,
5320/ac/eeeC,5320/ax,5320/ax/eC,5320/ax/eeeC,5500/a,5500/n,5500/n/Ce,5500/ac,5500/ac/Ce,5500/ac/Ceee,5500/ax,5500/ax/Ce,5500/ax/Ceee,5520/a,5520/n,5520/n/eC,5520/ac,
5520/ac/eC,5520/ac/eCee,5520/ax,5520/ax/eC,5520/ax/eCee,5540/a,5540/n,5540/n/Ce,5540/ac,5540/ac/Ce,5540/ac/eeCe,5540/ax,5540/ax/Ce,5540/ax/eeCe,5560/a,5560/n,5560/n/eC,
5560/ac,5560/ac/eC,5560/ac/eeeC,5560/ax,5560/ax/eC,5560/ax/eeeC,5580/a,5580/n,5580/n/Ce,5580/ac,5580/ac/Ce,5580/ac/Ceee,5580/ax,5580/ax/Ce,5580/ax/Ceee,5600/a,5600/n,
5600/n/eC,5600/ac,5600/ac/eC,5600/ac/eCee,5600/ax,5600/ax/eC,5600/ax/eCee,5620/a,5620/n,5620/n/Ce,5620/ac,5620/ac/Ce,5620/ac/eeCe,5620/ax,5620/ax/Ce,5620/ax/eeCe,5640/a,
5640/n,5640/n/eC,5640/ac,5640/ac/eC,5640/ac/eeeC,5640/ax,5640/ax/eC,5640/ax/eeeC,5660/a,5660/n,5660/n/Ce,5660/ac,5660/ac/Ce,5660/ac/Ceee,5660/ax,5660/ax/Ce,5660/ax/Ceee,
5680/a,5680/n,5680/n/eC,5680/ac,5680/ac/eC,5680/ac/eCee,5680/ax,5680/ax/eC,5680/ax/eCee,5700/a,5700/n,5700/n/Ce,5700/ac,5700/ac/Ce,5700/ac/eeCe,5700/ax,5700/ax/Ce,
5700/ax/eeCe,5720/a,5720/n,5720/n/eC,5720/ac,5720/ac/eC,5720/ac/eeeC,5720/ax,5720/ax/eC,5720/ax/eeeC,5745/a,5745/n,5745/n/Ce,5745/ac,5745/ac/Ce,5745/ac/Ceee,5745/ax,
5745/ax/Ce,5745/ax/Ceee,5765/a,5765/n,5765/n/eC,5765/ac,5765/ac/eC,5765/ac/eCee,5765/ax,5765/ax/eC,5765/ax/eCee,5785/a,5785/n,5785/n/Ce,5785/ac,5785/ac/Ce,5785/ac/eeCe,
5785/ax,5785/ax/Ce,5785/ax/eeCe,5805/a,5805/n,5805/n/eC,5805/ac,5805/ac/eC,5805/ac/eeeC,5805/ax,5805/ax/eC,5805/ax/eeeC,5825/a,5825/n,5825/n/Ce,5825/ac,5825/ac/Ce,5825/ax,
5825/ax/Ce,5845/a,5845/n,5845/n/eC,5845/ac,5845/ac/eC,5845/ax,5845/ax/eC,5865/a,5865/n,5865/ac,5865/ax
current-gopclasses=115,116,117,118,119,120,121,122,123,125,126,127,128 current-max-reg-power=30
1 L radio-mac=D4:01:C3:56:FA:11 tx-chains=0,1 rx-chains=0,1 bands=2ghz-g:20mhz,2ghz-n:20mhz,20/40mhz,2ghz-ax:20mhz,20/40mhz
ciphers=tkip,ccmp,gcmp,ccmp-256,gcmp-256,cmac,gmac,cmac-256,gmac-256 countries=all 2g-channels=2412,2417,2422,2427,2432,2437,2442,2447,2452,2457,2462,2467,2472 max-vlans=128
max-interfaces=16 max-station-interfaces=3 max-peers=512 hw-type=“QCA6018” hw-caps=sniffer,qos-classifier-dscp interface=wifi2 current-country=United Kingdom
current-channels=2412/g,2412/n,2412/n/Ce,2412/ax,2412/ax/Ce,2417/g,2417/n,2417/n/Ce,2417/ax,2417/ax/Ce,2422/g,2422/n,2422/n/Ce,2422/ax,2422/ax/Ce,2427/g,2427/n,2427/n/Ce,2427/ax,
2427/ax/Ce,2432/g,2432/n,2432/n/Ce,2432/n/eC,2432/ax,2432/ax/Ce,2432/ax/eC,2437/g,2437/n,2437/n/Ce,2437/n/eC,2437/ax,2437/ax/Ce,2437/ax/eC,2442/g,2442/n,2442/n/Ce,
2442/n/eC,2442/ax,2442/ax/Ce,2442/ax/eC,2447/g,2447/n,2447/n/Ce,2447/n/eC,2447/ax,2447/ax/Ce,2447/ax/eC,2452/g,2452/n,2452/n/Ce,2452/n/eC,2452/ax,2452/ax/Ce,2452/ax/eC,
2457/g,2457/n,2457/n/eC,2457/ax,2457/ax/eC,2462/g,2462/n,2462/n/eC,2462/ax,2462/ax/eC,2467/g,2467/n,2467/n/eC,2467/ax,2467/ax/eC,2472/g,2472/n,2472/n/eC,2472/ax,
2472/ax/eC
current-gopclasses=81,83,84 current-max-reg-power=20
If you run the wifi-qcom-ac package on the cAP ac (instead of the wireless package) you should be fine.
Here you can find the documentation:
https://help.mikrotik.com/docs/display/ROS/WiFi#WiFi-CAPsMAN-CAPsimpleconfigurationexample:
Could you add the ouput of this command as well?
/interface/wifi export
Remove anything private.
you shoul better order cap AX…
