Here it is, I hope I’m not exposing too much?:
# 2025-05-13 16:52:04 by RouterOS 7.18.2
# software id = V...Y
# model = RBD53iG-5HacD2HnD
# serial number = E...E
/caps-man channel
add band=5ghz-a/n/ac control-channel-width=20mhz name=channel5g
add band=2ghz-b/g/n control-channel-width=20mhz frequency=2427 name=channel2g
add name=bridge-guest port-cost-mode=short
add name=bridge1 port-cost-mode=short
set [ find default-name=ether1 ] name=ether1_WAN
/interface mesh
add disabled=yes mesh-portal=yes name=Mesh
/interface wireguard
add listen-port=1...1 mtu=1420 name=wireguard
/caps-man datapath
add bridge=bridge-guest name=datapath-guest vlan-id=1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name="security profile"
add authentication-types=wpa2-psk encryption=aes-ccm name=security-guest
add authentication-types=wpa2-psk encryption=aes-ccm name=security-iot
/caps-man configuration
add channel=channel5g datapath.bridge=bridge1 installation=any name=cfg-5g security="security profile" ssid=B5AH15
add channel=channel2g datapath.bridge=bridge1 installation=any mode=ap name=cfg-2g security="security profile" ssid=B5AH12
add datapath=datapath-guest mode=ap name=cfg-GUEST security=security-guest ssid=GUEST
add channel=channel2g datapath.bridge=bridge1 hide-ssid=no installation=any name=cfg-iot security=security-iot ssid=B5AH12IOT
/interface lte apn
add authentication-types=wpa2-psk mode=dynamic-keys name=Password-WiFi supplicant-identity=""
add authentication-types=wpa2-psk mode=dynamic-keys name="Guest profile" supplicant-identity=""
/interface wireless
# managed by CAPsMAN
# channel: 2427/20-Ce/gn(17dBm), SSID: B5AH12, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n frequency=2427 frequency-mode=manual-txpower installation=indoor mode=ap-bridge name=wlan1_24 security-profile=Password-WiFi ssid=\
B5AH12
add disabled=no keepalive-frames=disabled mac-address=0A...20 master-interface=wlan1_24 multicast-buffering=disabled name=wlan1_24-guest security-profile="Guest profile" ssid=GUEST \
wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-onlyac channel-width=20/40/80mhz-XXXX frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge \
name=wlan2_58 security-profile=Password-WiFi ssid=B5AH15
add name=dhcp_pool0 ranges=192.168.1.100-192.168.1.254
add name=dhcp_pool1 ranges=10.10.10.100-10.10.10.254
add address-pool=dhcp_pool0 interface=bridge1 lease-time=10m name=dhcp1
add address-pool=dhcp_pool1 interface=bridge-guest lease-time=10m name=dhcp-guest
/user group
set read policy=local,telnet,ssh,reboot,read,test,winbox,password,sniff,sensitive,api,romon,rest-api,!ftp,!write,!policy,!web
set write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,sniff,sensitive,api,romon,rest-api,!ftp,!policy,!web
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api,romon,rest-api,!web
add name=home policy=read,api,!local,!telnet,!ssh,!ftp,!reboot,!write,!policy,!test,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration=cfg-5g name-format=identity slave-configurations=cfg-GUEST
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration=cfg-2g name-format=identity slave-configurations=cfg-GUEST,cfg-iot
add bridge=bridge1 interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=wlan1_24 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=wlan2_58 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge1 interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge-guest interface=wlan1_24-guest internal-path-cost=10 path-cost=10
set udp-timeout=10s
/ipv6 settings
/interface ovpn-server server
add auth=sha1,md5 mac-address=FE...59 name=ovpn-server1
/interface wireguard peers
add allowed-address=192.168.77.2/32 interface=wireguard name=peer1 public-key=""
/interface wireless access-list
add comment=Win interface=wlan1_24-guest mac-address=9C...0C
add comment=WXM interface=wlan1_24-guest mac-address=24...9C
/interface wireless cap
set caps-man-addresses=192.168.1.1 enabled=yes interfaces=wlan2_58,wlan1_24
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
add address=10.10.10.1/24 interface=bridge-guest network=10.10.10.0
add address=192.168.77.1/24 interface=wireguard network=192.168.77.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add interface=ether1_WAN
/ip dhcp-server lease
add address=192.168.1.154 client-id=1...cc comment=Fronius mac-address=78...CC server=dhcp1
add address=10.10.10.107 client-id=1:2..c comment=WXM mac-address=24...9C server=dhcp-guest
add address=10.10.10.108 client-id=1:9...c comment=Win mac-address=9C...C server=dhcp-guest
add address=192.168.1.2 client-id=1:f4...3c mac-address=F4...3C server=dhcp1
add address=10.10.10.0/24 gateway=10.10.10.1
add address=192.168.1.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.8
/ip firewall address-list
add address=e..e.sn.mynetname.net list=WAN-IP
add address=192.168.1.0/24 list=LAN
add address=10.10.10.100-10.10.10.254 list="Guest users"
add address=acme-v02.api.letsencrypt.org list=LE
add address=acme-staging-v02.api.letsencrypt.org list=LE
add address=letsencrypt.org list=LE
add action=accept chain=input dst-port=80 in-interface=ether1_WAN protocol=tcp src-address-list=LE
add action=accept chain=input comment="allow WireGuard" dst-port=1...1 protocol=udp
add action=accept chain=input comment="allow WireGuard traffic" src-address=192.168.77.0/24
add action=accept chain=forward dst-address=192.168.1.111 dst-address-list="" dst-port=443 protocol=tcp src-address-list=""
add action=accept chain=forward disabled=yes dst-address=192.168.1.100 dst-address-list="" dst-port=4...4 protocol=tcp src-address-list=""
add action=drop chain=input comment="block guest - local ports" dst-address=10.10.10.1 dst-port=21,22,23,8123,8291 protocol=tcp src-address-list="Guest users"
add action=drop chain=input comment="block guest - LAN" dst-address=192.168.1.0/24 src-address-list="Guest users"
add action=accept chain=input dst-address=192.168.1.122 src-address-list="Guest users"
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address-list=WAN-IP new-connection-mark=HairPin_NAT src-address-list=LAN
add action=masquerade chain=srcnat comment="HAIRPIN NAT" dst-address=192.168.1.0/24 src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment=NAT out-interface=ether1_WAN src-address=192.168.1.0/24
add action=dst-nat chain=dstnat comment=H dst-address-list=WAN-IP dst-port=8... protocol=tcp src-port="" to-addresses=192.168.1. to-ports=8...
add action=dst-nat chain=dstnat comment="H SSL" dst-address-list=WAN-IP dst-port=443 protocol=tcp src-port="" to-addresses=192.168.1. to-ports=443
add action=dst-nat chain=dstnat comment="S firmware update" disabled=yes dst-address-list=WAN-IP dst-port=44004 protocol=tcp src-port="" to-addresses=192.168.1.100 to-ports=4...4
add action=dst-nat chain=dstnat comment="H SSL" dst-address-list=WAN-IP dst-port=80 protocol=tcp src-port="" to-addresses=192.168.1. to-ports=80
add action=dst-nat chain=dstnat comment="H WireGuard" dst-address-list=WAN-IP dst-port=5....5 in-interface=ether1_WAN protocol=udp to-addresses=192.168.1. to-ports=5....5
add action=masquerade chain=srcnat comment="H WireGuard" src-address=10.10.10.0/24
add action=masquerade chain=srcnat comment="Mikrotik WireGuard" src-address=192.168.77.0/24
/ip ipsec profile
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh address=192.168.1.0/24
set www-ssl address=0.0.0.0/0,0.0.0.0/0,0.0.0.0/0 certificate=letsencrypt-autogen_2024-04-25T07:35:20Z disabled=no
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge1 type=internal
add interface=ether1_WAN type=external
/routing bfd configuration
add disabled=no
/system clock
set time-zone-name=Europe
/system identity
set name=MTmain
/system leds
set 0 interface=wlan1_24 leds=led1,led2,led3,led4,led5 type=wireless-signal-strength
set 1 leds=poe-led type=poe-out
/system note
set show-at-login=no
/system scheduler
add interval=11w3d name="SSL Let's Encrypt Renew" on-event="certificate/enable-ssl-certificate dns-name=e...e.sn.mynetname.net" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=2024-04-25 start-time=23:50:00
