CAPsMAN can not ping it's CAPs
hAP AC as CAPsMAN
WAP as CAP
All of this is working fine, wireless clients can ping each other, they can ping CAPsMAN and CAP too.
Client-to-client forwarding in Datapath is set
CAPsMAN has all it’s FW rules disabled, CAP has no FW rules
MAC ping CAP <—> CAPsMAN is working,
but the ordinary IP request fail in both directions
Is there any ideas?
Can you please share your configuration (except for the sensitive information)?
Did you add a DHCP client to the CAP?
Sure, but do you need the whole config or just a CAPsMAP part?
CAPsMAN pushed via DHCP
  • Here is CAP seeeetup
[admin@LivingRoomWAP] > interface wireless cap print
                            enabled: yes
                         interfaces: wlan 2Ghz,wlan 5Ghz
                        certificate: request
                   lock-to-caps-man: yes
               discovery-interfaces: main infrastructure
                 caps-man-addresses: 192.168.99.1
                     caps-man-names:
  caps-man-certificate-common-names:
                             bridge: none
                     static-virtual: no
              requested-certificate: CAP-CC2DE0E7BE02
        locked-caps-man-common-name: CAPsMAN-6C3B6B11DA18
  • Here is CAPsMAN one
/caps-man channel
add band=2ghz-onlyn control-channel-width=20mhz extension-channel=disabled \
    frequency=2412 name=common-chnls-2Ghz reselect-interval=10h \
    skip-dfs-channels=yes tx-power=17
add band=5ghz-a/n/ac comment="20Mhz + Ce = 40Mhz, reselect interval from 5180,\
    \_5220, 5745, 5785 once per 10h" control-channel-width=20mhz \
    extension-channel=Ce frequency=5180,5220,5745,5785 name=common-chnls-5Ghz \
    reselect-interval=10h tx-power=15
/caps-man configuration
add mode=ap name=empty
/caps-man datapath
add bridge="guest infrastructure" name=2CapsMan-guest
add bridge="main infrastructure" client-to-client-forwarding=yes name=\
    2CapsMan-private
/caps-man rates
add basic="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,\
    48Mbps,54Mbps" name="5GHz Rates" supported="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mb\
    ps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps" vht-basic-mcs=mcs0-9 \
    vht-supported-mcs=mcs0-9
    48Mbps,54Mbps" ht-basic-mcs="mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs\
    -7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs\
    -18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" ht-supported-mcs="mcs-0,mcs-1,mcs-\
    2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mc\
    s-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23" \
    name="2GHz rates" supported="1Mbps,2Mbps,5.5Mbps,11Mbps,6Mbps,9Mbps,12Mbps\
/caps-man security
add authentication-types=wpa2-psk comment="2GHz/5GHz Security" encryption=\
    aes-ccm group-encryption=aes-ccm group-key-update=1h name=private
add authentication-types="" comment="2GHz/5GHz FREE" encryption="" \
    group-key-update=5m name=guest
add channel=common-chnls-2Ghz country=russia datapath=2CapsMan-private \
    datapath.interface-list=list-2ghz-caps-private distance=indoors \
    guard-interval=long hw-protection-mode=rts-cts hw-retries=7 installation=\
    indoor keepalive-frames=enabled max-sta-count=10 mode=ap \
    multicast-helper=full name=zone-2Ghz-private rx-chains=0,1,2,3 security=\
    private ssid="WiFi 2Ghz PRIVATE" tx-chains=0,1,2,3
add channel=common-chnls-5Ghz country=russia datapath=2CapsMan-private \
    datapath.interface-list=list-5ghz-caps-private disconnect-timeout=9s \
    distance=indoors guard-interval=long hw-protection-mode=rts-cts \
    hw-retries=7 installation=indoor keepalive-frames=enabled max-sta-count=\
    10 mode=ap multicast-helper=full name=zone-5Ghz-private rx-chains=0,1,2,3 \
    security=private ssid="WiFi 5Ghz PRIVATE" tx-chains=0,1,2,3
add channel=common-chnls-2Ghz country=russia datapath=2CapsMan-guest \
    datapath.interface-list=list-2ghz-caps-guest distance=indoors \
    multicast-helper=full name=zone-2Ghz-guest rx-chains=0,1,2,3 security=\
    guest ssid="WiFi 2Ghz FREE" tx-chains=0,1,2,3
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled \
    mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man access-list
add action=reject allow-signal-out-of-range=10s comment="Drop any when poor si\
    gnal rate, https://support.apple.com/en-us/HT203068" disabled=no \
    signal-range=-120..-70 ssid-regexp=WiFi
add action=accept allow-signal-out-of-range=10s client-to-client-forwarding=\
    yes comment=iPhoneAlx disabled=no mac-address=AC:61:EA:EA:CC:84 \
    ssid-regexp="WiFi 5"
    yes comment=iPhoneGl disabled=no mac-address=00:CD:FE:EC:B5:52 \
    yes comment=mbpAlx disabled=no mac-address=78:31:C1:CF:9E:70 ssid-regexp=\
    WiFi
add action=accept allow-signal-out-of-range=10s ap-tx-limit=0 \
    client-to-client-forwarding=yes comment=ATV disabled=no mac-address=\
    90:DD:5D:C8:46:AB ssid-regexp="WiFi 5"
    yes comment=iPadAlx disabled=no mac-address=54:E4:3A:B8:12:07 \
    ssid-regexp="WiFi 2"
    yes comment=iPhoneAlxr disabled=no mac-address=54:2B:8D:77:38:A0 \
    yes comment=iPhoneGlo disabled=no mac-address=54:2B:8D:7F:83:A6 \
    yes comment=asusGl disabled=no mac-address=98:22:EF:26:FE:6E ssid-regexp=\
    WiFi
add action=accept allow-signal-out-of-range=10s comment=\
    "Allow any other on guest wireless" disabled=no ssid-regexp=FREE
add action=reject allow-signal-out-of-range=10s comment=\
    "Drop any other on private wireless" disabled=no ssid-regexp=PRIVATE
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes package-path="" \
    require-peer-certificate=yes upgrade-policy=require-same-version
/caps-man manager interface
set [ find default=yes ] comment="Deny CapsMan on All" disabled=no forbid=no \
    interface=all
add comment="Deny WAN CapsMan" disabled=no forbid=yes interface=wan
add comment="Do CapsMan on private" disabled=no forbid=no interface=\
add comment="Do CapsMan on guest" disabled=no forbid=no interface=\
/caps-man provisioning
add action=create-dynamic-enabled comment="2Ghz private/guest" \
    common-name-regexp="" disabled=no hw-supported-modes=gn identity-regexp=\
    WAP ip-address-ranges="" master-configuration=zone-2Ghz-private \
    name-format=prefix-identity name-prefix=2Ghz radio-mac=00:00:00:00:00:00 \
    slave-configurations=zone-2Ghz-guest
add action=create-dynamic-enabled comment="5Ghz private" common-name-regexp=\
    "" disabled=no hw-supported-modes=ac identity-regexp=WAP \
    ip-address-ranges="" master-configuration=zone-5Ghz-private name-format=\
    prefix-identity name-prefix=5Ghz radio-mac=00:00:00:00:00:00 \
    slave-configurations=""
add action=create-dynamic-enabled comment="2Ghz private/guest (self-cap)" \
    mikrouter ip-address-ranges="" master-configuration=zone-2Ghz-private \
add action=create-dynamic-enabled comment="5Ghz private (self-cap)" \
    common-name-regexp="" disabled=no hw-supported-modes=ac identity-regexp=\
    mikrouter ip-address-ranges="" master-configuration=zone-5Ghz-private \
    name-format=prefix-identity name-prefix=5Ghz radio-mac=00:00:00:00:00:00 \
add action=none comment=DUMMY common-name-regexp="" disabled=no \
    hw-supported-modes="" identity-regexp="" ip-address-ranges="" \
    master-configuration=empty name-format=prefix-identity name-prefix=dummy \
    radio-mac=00:00:00:00:00:00 slave-configurations=""
First thing I notice is that the CAP doesn’t have a bridge configured. If you reset a device to be a Cap it is added. Can you try to set it manually on the Cap and see if it makes a difference?
Next I prefer to have the TX power on the 5G band higher than the 2G band, just to have as many devices on the 5G band as possible.
And at last, I have configured 12Mbps as the only basic rate, and 12Mbps and higher on supported rates. That improved the performance for me.
