add admin-mac=4C:5E:0C:E7:AF:2E auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX
disabled=no distance=indoors frequency=auto installation=indoor mode=
ap-bridge ssid=. wireless-protocol=802.11
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=security1
passphrase=12345678
add comment=defconf name=WAN
add comment=defconf name=LAN
/caps-man datapath
add bridge=bridge interface-list=all name=datapath1
/caps-man configuration
add channel.band=2ghz-g/n channel.control-channel-width=20mhz
channel.extension-channel=disabled channel.save-selected=yes
channel.tx-power=15 country=no_country_set datapath=datapath1
datapath.arp=local-proxy-arp datapath.bridge=bridge
datapath.client-to-client-forwarding=no datapath.local-forwarding=no
distance=indoors guard-interval=long hw-protection-mode=cts-to-self
hw-retries=7 mode=ap name=cfg1 security=security1 ssid=SH2
set [ find default=yes ] authentication-types=wpa-psk eap-methods=“” mode=
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=google.com.
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/caps-man access-list
add action=accept allow-signal-out-of-range=20s disabled=no signal-range=
-84..120 ssid-regexp=“”
add action=reject allow-signal-out-of-range=10s disabled=no signal-range=
-120..-85 ssid-regexp=“”
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man manager interface
add disabled=no
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg1
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
/system clock
set time-zone-name=Asia/Kathmandu
/system identity
set name=“hAP lite Router”
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
this is my config of capsman router. capsman ssid not brodcasting, anyone have any idea plz ?
router.rsc (4.43 KB)
