I am new to mikrotik. For starters, I got the RB5009UG, and a cap ax, just one for now. I understand that for 1 AP capsman is overkill, but I wanted to check it out.
The config on the router is literally the default config, bar the pppoe client I added. On the cap ax I reset it to CAP mode, and just added the premade wifi interfaces to the bridge. All works - if I edit the wifi on the CAP (locally managed mode) it works, but if I make them managed by capsman, it rightfully says “Managed by capsman at mac%localBridge traffic processing on CAP”, but on the capsman side It says the following message:
“Operated by CAP mac%bridge, traffic processing on CAP”.
What is that?? What’s the difference between Managed by, and Operated by? And why do they point to each other? CAP says it’s managed by capsman, Capsman side says it’s “operated by” the CAP.
The result is that on the capsman side, I can not edit the wifi - all is greyed out. On the CAP side, i can still edit the wifi, even though the manager is set exclusively to capsman.
Capsman is listening on the one and only router default bridge (all LAN ports), and on CAP side the cap looks for capsman on it’s own localBridge (ether1 + all wifis).
I repeat, the config is more or less default, aside from changes noted above.
For the example below I only made one wifi interface managed by capsman to demonstrate the problem.
Here is how it looks on the cap:
Here is how it looks like on capsman (rb5009):
The config:
2025-02-11 14:18:51 by RouterOS 7.17.2
software id = HS9E-P0TQ
model = RB5009UG+S+
serial number = snip
/caps-man configuration
add channel.band=5ghz-a/n/ac country=snip distance=indoors installation=
indoor mode=ap name=Home5Config security.authentication-types=wpa2-psk
.encryption=aes-ccm ssid=“snip”
add admin-mac=78:9A:18:C7:91:03 auto-mac=no comment=defconf name=bridge
port-cost-mode=short
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-1
use-peer-dns=yes user=snip
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi channel
add band=5ghz-ax disabled=no frequency=5735-5815,5815-5875,5210-5250 name=
5GHz_mix skip-dfs-channels=all width=20/40/80mhz
add band=2ghz-n disabled=no frequency=2412-2467 name=2.4GHz_mix
skip-dfs-channels=all width=20/40mhz
add band=5ghz-ax disabled=no name=5GHz_mix_def
/interface wifi security
add authentication-types=wpa3-psk disabled=no encryption=“” name=
home_secure_wpa3psk
/interface wifi configuration
add channel=5GHz_mix_def country=snip disabled=no manager=capsman mode=ap
name=Home5Config security=home_secure_wpa3psk
security.authentication-types=“” ssid=“snip”
add channel=2.4GHz_mix country=snip disabled=no mode=ap name=Home2.4Config
security=home_secure_wpa3psk ssid=“snip”
add name=home-pool ranges=10.0.0.10-10.0.0.254
add address-pool=home-pool interface=bridge lease-time=10m name=home-dhcp
/caps-man manager
set ca-certificate=WiFi-CAPsMAN-CA-789A18C79102 certificate=
WiFi-CAPsMAN-789A18C79102
/caps-man manager interface
add disabled=no interface=bridge
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether6 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether7 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=ether8 internal-path-cost=10
path-cost=10
add bridge=bridge comment=defconf interface=sfp-sfpplus1 internal-path-cost=
10 path-cost=10
set udp-timeout=10s
add interface=pppoe-1 list=WAN
/interface ovpn-server server
add mac-address=FE:E6:6D:BD:99:C2 name=ovpn-server1
/interface wifi cap
set discovery-interfaces=LAN
/interface wifi capsman
set enabled=yes interfaces=LAN package-path=“” require-peer-certificate=no
upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=yes master-configuration=
Home5Config radio-mac=D4:01:C3:F8:18:66 supported-bands=5ghz-ax
add action=create-dynamic-enabled disabled=no master-configuration=
Home2.4Config radio-mac=D4:01:C3:F8:18:67 supported-bands=2ghz-n
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge
network=192.168.88.0
add address=10.0.0.1/24 interface=bridge network=10.0.0.0
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=10.0.0.2 client-id=1:d4:1:c3:f8:18:64 mac-address=
D4:01:C3:F8:18:64 server=home-dhcp
add address=10.0.0.0/24 dns-server=10.0.0.1 gateway=10.0.0.1
set allow-remote-requests=yes cache-size=30480KiB
/ip dns adlist
add ssl-verify=no url=“> https://raw.githubusercontent.com/hagezi/dns-blocklists>
/main/hosts/pro.txt”
/ip dns static
add address=10.0.0.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127.0.0.1
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
/ip ipsec profile
/ip smb shares
set [ find default=yes ] directory=flash/pub
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute” port=
33434-33534 protocol=udp
“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500
protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
“defconf: drop everything else not coming from LAN” in-interface-list=
!LAN
“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1”
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
!LAN
/system clock
set time-zone-name=snip
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
