Hello!
I have 2 hAp ac lite devices. I want to manage wireless network via CapsMan.
One of them (HAP1) has almost default “Home AP” configuration and CapsMan is configured and enabled. The second HAP2 is connected to HAP1 via wire and configured as CAP. It receives all the configuration and managed by CapsMan on HAP1.
When i enable CAP mode (via wirelss menu) on HAP1 it receives the configuration but in few second it falls out of CapsMan and following messages are appeared in Log:
I used to configure CapsMan on both of these devices before and everything was fine. But after some testing I hard-reseted HAP1 back to default configuration.
Can someone explain what is the problem why cannot CapsMan istalled on the device manage itself?
I have moved CapsMan with same config to HAP2 (the one that served as simple access point) and this time both access points grabbed CapsMan configuration and appeared online.
If i disable Capsman on HAP2 and re-enable on HAP1, HAP2 connects as access point. But HAP1 doesnt connect to itself, i can see that the interface is managed by capsman, but it doesnt go online and there are no errors in log.
I have noticed that if i do not specify CAPsMAN ip address on HAP1 upon configuring CAP mode (besides having set discovery interfaces to main bridge), HAP1 cannot even find CAPsMAN server. If i specify it can locate it and error events as mentioned in the first post start appearing in the log.
I have tried to disable all firewall rules (default rules created by “Home AP Dual” configuration) and HAP1 started to discover CAPsMAN server and manage its wireless interfaces. The firmware is the latest 6.40.2 on both HAP1 and HAP2.
I have also tried to reset configuration on HAP1 and re-enable CAPsMAN of fresh default configuration - it still cannot find manage its wireless interfaces.
Below are the rules, that i have in my firewall:
# aug/27/2017 10:21:23 by RouterOS 6.40.1
# software id = 2PNJ-7RK4
# model = RouterBOARD 952Ui-5ac2nD
# serial number = 1234567890
add action=accept chain=input comment="VPN Traffic" dst-port=1701 protocol=\
udp
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat disabled=yes out-interface=all-ppp
add action=dst-nat chain=dstnat dst-port=9091 log-prefix=OMV_Torrent_ \
protocol=tcp to-addresses=192.168.0.115 to-ports=9091
add action=dst-nat chain=dstnat dst-address=1.1.1.1 dst-port=5001 \
in-interface-list=WAN protocol=tcp to-addresses=\
192.168.0.110 to-ports=5001
Are there any special rules that i need to create for CAPsMAN?
