Hello all,
I’ve been searching through the portal for any topic in regards of CAPsMAN setup of CAP lite which are connected via CAP PoE out port (attached snapshot).
I want to basically extend the access point network till some edges of my house where CAP is not located and I run one extra cable till the remote CAP lite.
I have been unable to make it work so far. Connecting the CAP lite directly on the HEX Poe router, CAP lite becomes managed by CAPsMAN.
Any suggestions?
Antony
Hello Anthony,
Could you please clarify what exactly does not work?
Do you mean to say that when you connect the Cap lite to HEX PoE directly it gets managed by CAPsMAN, but when you connect it through the CAP PoE out port it does not work?
How is your CAP PoE port configured?
Are you able to access the VLAN on which CAPsMAN is running through that port?
Egene
simply create new bridge inside cAP ac and put inside ether1 and ether2,
done.
If that doesn’t work, ether1’s default configuration is probably WAN, or subsequent configurations are crazy …
put /export of one “cap ac” here
