After updating my HEXs from 7.1.1 to 7.2.3, my cAP’s timeout connecting. Downgrading to 7.1.1 resolves the issue.
I have three cAP’s (1 cAP XL ac and 2 cAP ac’s) connected to a CSS106-1G-4P-1S. The CSS106 provides PoE to the cAP’s.
The CSS106 is connected to a HEXs via a trunk port on sfp1 which is part of a bridge. I’m using vlan filtering on the HEX. The HEX is running CAPsMAN.
/interface bridge vlan
add bridge=bridge tagged=bridge
add bridge=bridge tagged=bridge,ether3,ether4,ether5,sfp1 vlan-ids=35
add bridge=bridge tagged=bridge,ether3,ether4,ether5,sfp1 vlan-ids=40
add bridge=bridge tagged=bridge,ether3,ether4,ether5,sfp1 vlan-ids=100
add bridge=bridge tagged=bridge,ether3,ether4,ether5,sfp1 vlan-ids=105
add bridge=bridge untagged=bridge,ether5 vlan-ids=254
The CSS106 has VLANs configured the following way:
The CAPs have all been upgraded to 7.2.3 and are working fine with the HEX is running 7.1.1. If the HEX is running 7.2.3, the CAPs timeout when attempting to connect.
Any advice would be appreciated.
