Hello to all
I settup CAPsman and CAP with vlan and magaemet vlan but i like to know is it batter way to do same thing ?
RB3011 is main router and capsman, SFP port from router is conected to Cisco 2960S-48 SFP port (gigabit 0/49) and CAP (cAP ac) are connected on gigabit port of Cisco from 10-21
RB3011
[xxxxxxx@xxxxxxxxx] > export
jan/24/2021 15:17:46 by RouterOS 6.48
software id = 3CB8-SW3F
model = RB3011UiAS
serial number = B88D0B4526F6
/caps-man channel
add band=2ghz-g/n name="Auto 2,4GHz"
add band=5ghz-a/n/ac name="Auto 5GHz"
add admin-mac=6A:99:34:E3:95:1F auto-mac=no name=bridge10
add admin-mac=0E:C6:4C:03:93:94 auto-mac=no name=bridge20
add admin-mac=C4:AD:34:85:10:A5 auto-mac=no name=bridge33
add admin-mac=4E:62:E7:88:D7:13 auto-mac=no name=bridge254
set [ find default-name=ether1 ] comment=Internet
set [ find default-name=sfp1 ] comment=TRUNK
/interface ipip
add local-address=178.219.10.134 name="SPAJZ Centrala" remote-address=95.140.124.94
/interface vlan
add interface=bridge10 name=b-vlan10 vlan-id=10
add interface=bridge20 name=b-vlan20 vlan-id=20
add interface=bridge33 name=b-vlan30 vlan-id=30
add interface=bridge254 name=b-vlan254 vlan-id=254
add interface=sfp1 name=vlan10 vlan-id=10
add interface=sfp1 name=vlan20 vlan-id=20
add interface=sfp1 name=vlan30 vlan-id=30
add interface=sfp1 name=vlan254 vlan-id=254
/caps-man datapath
add bridge=bridge10 client-to-client-forwarding=yes local-forwarding=yes name=datapath10
add bridge=bridge254 name=datapath254 vlan-id=254 vlan-mode=use-tag
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=Gosti passphrase=freespot
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=Firma passphrase=spajz1234
/caps-man configuration
add channel="Auto 2,4GHz" country=serbia datapath=datapath10 mode=ap name="xxxxxx 2,4GHz" security=Firma ssid="xxxxxxxxx. 2,4GHz"
add channel="Auto 2,4GHz" country=serbia datapath=datapath254 mode=ap name=xxxxxxxx security=Gosti ssid=Kupci
add channel="Auto 5GHz" country=serbia datapath=datapath10 mode=ap name="xxxxxxxxxx" security=Firma ssid="xxxxxxxx. 5GHz"
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool0 ranges=192.168.5.50-192.168.5.200
add name=dhcp_pool1 ranges=192.168.20.50-192.168.20.150
add name=dhcp_pool2 ranges=192.168.33.50-192.168.33.100
add name=dhcp_pool3 ranges=192.168.254.2-192.168.254.254
add add-arp=yes address-pool=dhcp_pool0 disabled=no interface=bridge10 lease-time=1d name=Data
add add-arp=yes address-pool=dhcp_pool1 disabled=no interface=bridge20 lease-time=1d name=VoIP
add add-arp=yes address-pool=dhcp_pool2 disabled=no interface=bridge33 lease-time=1d name=Security+Management
add add-arp=yes address-pool=dhcp_pool3 disabled=no interface=b-vlan254 lease-time=1d name=Gosti
/caps-man access-list
add action=accept allow-signal-out-of-range=10s disabled=no interface=all signal-range=-87..120 ssid-regexp=""
add action=reject allow-signal-out-of-range=10s disabled=no interface=all signal-range=-120..88 ssid-regexp=""
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=gn master-configuration="Firma 2,4GHz" name-format=identity slave-configurations=Gosti
add action=create-dynamic-enabled hw-supported-modes=ac master-configuration="Firma 5GHz" name-format=identity
add bridge=bridge33 interface=ether2
add bridge=bridge10 interface=ether3
add bridge=bridge10 interface=ether4
add bridge=bridge10 interface=ether5
add bridge=bridge10 interface=ether6
add bridge=bridge10 interface=ether7
add bridge=bridge33 interface=ether8
add bridge=bridge33 interface=ether9
add bridge=bridge33 interface=ether10
add bridge=bridge10 interface=b-vlan10
add bridge=bridge10 interface=vlan10
add bridge=bridge20 interface=b-vlan20
add bridge=bridge20 interface=vlan20
add bridge=bridge33 interface=b-vlan30
add bridge=bridge33 interface=vlan30
add bridge=bridge254 interface=b-vlan254
add bridge=bridge254 interface=vlan254
/interface detect-internet
set internet-interface-list=WAN lan-interface-list=LAN wan-interface-list=WAN
add interface=bridge33 list=LAN
add interface=ether1 list=WAN
add address=192.168.33.1/24 interface=bridge33 network=192.168.33.0
add address=192.168.5.1/24 interface=bridge10 network=192.168.5.0
add address=192.168.20.1/24 interface=bridge20 network=192.168.20.0
add address=192.168.254.1/24 interface=b-vlan254 network=192.168.254.0
add address=178.219.10.134/30 interface=ether1 network=178.219.10.132
add address=13.0.0.2/30 interface="SPAJZ Centrala" network=13.0.0.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=192.168.5.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.5.1
add address=192.168.20.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.20.1
add address=192.168.33.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.33.1
add address=192.168.254.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.254.1
set servers=8.8.8.8,8.8.4.4
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=src-nat chain=srcnat dst-address=!192.168.3.0/24 ipsec-policy=out,none out-interface=ether1 src-address=192.168.5.0/24 to-addresses=xxxxxxxxxxxx
add action=src-nat chain=srcnat dst-address=192.168.3.0/24 ipsec-policy=out,none out-interface=ether1 src-address=192.168.5.0/24 to-addresses=13.0.0.2
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=ether1 src-address=192.168.20.0/24
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=ether1 src-address=192.168.33.0/24
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=ether1 src-address=192.168.254.0/24
add distance=1 gateway=178.219.10.133
add distance=1 dst-address=192.168.3.0/24 gateway="XXXXXXXXxxxxxx"
/ip service
set telnet disabled=yes
/ip smb
set allow-guests=no
/ip upnp
set show-dummy-rule=no
/lcd
set backlight-timeout=never default-screen=interfaces
/lcd pin
set pin-number=1910
/system ntp client
set enabled=yes primary-ntp=162.159.200.123
/tool bandwidth-server
set authenticate=no enabled=no
/tool graphing interface
add allow-address=10.20.20.0/24
/tool graphing queue
/tool graphing resource
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
cAP ac settup
jan/24/2021 15:23:06 by RouterOS 6.48
software id = ADQS-VNNP
model = RBcAPGi-5acD2nD
serial number = B9320B1491CD
add admin-mac=5E:5D:95:E6:9C:26 auto-mac=no name=bridge10
add admin-mac=C4:AD:34:8D:77:FE auto-mac=no name=bridge33
/interface wireless
managed by CAPsMAN
channel: 2412/20-Ce/gn(20dBm), SSID: XXXXXXX. 2,4GHz, local forwarding
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=20/40mhz-XX country=no_country_set disabled=no distance=indoors frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge ssid=MikroTik-8D7800
station-roaming=enabled wireless-protocol=802.11
managed by CAPsMAN
channel: 5180/20-Ceee/ac/P(23dBm), SSID: XXXXXX 5GHz, local forwarding
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=no_country_set disabled=no distance=indoors frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge ssid=MikroTik-8D7801
managed by CAPsMAN
SSID: xXXXXXX, CAPsMAN forwarding
add mac-address=C6:AD:34:8D:78:00 master-interface=wlan1 mode=station name=wlan3
/interface vlan
add interface=ether1 name=vlan10 vlan-id=10
add interface=ether1 name=vlan30 vlan-id=30
add bridge=bridge10 interface=ether2
/interface wireless cap
set bridge=bridge10 certificate=request discovery-interfaces=bridge33 enabled=yes interfaces=wlan1,wlan2 static-virtual=yes
add address=192.168.33.9/24 interface=bridge33 network=192.168.33.0
/ip cloud
set update-time=no
add distance=1 gateway=192.168.33.1
/ip service
/ip smb
set allow-guests=no
/ip ssh
set strong-crypto=yes
/system clock
set time-zone-name=Europe/Belgrade
/system identity
set name="XXXXXXX"
/system ntp client
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/tool romon
set enabled=yes
Cisco C2960S
Trunk port to router SFP
interface GigabitEthernet 1/0/49
description TRUNK RUTER
switchport trunk allowed vlan 10,20,30,254
switchport mode trunk
TRUNK port to CAP CAP ac
interface GigabitEthernet1/0/2
description AP1
switchport trunk allowed vlan 10,30
Any sugestion ? For better settup.
It work, but I like to have the best settup
