I am using a hEX as CAPsMAN und 2 hAPs + 1wAP as access points controlled by the CAPsMAN. The wireless lan exists, I can connect everytime I need to but sometimes I have very poor transfer rates via wireless lan. One hour later everything seems to be perfect again and so on.
I analyzed different things during the last weeks. I have no errors or drops on any interfaces, the ROS is the latest version 4.62.6 on every device.
I recognized that my caps are reconnecting in different intervals. The interval is not a specific time I can reproduce. Sometimes it takes some minutes, some hours or a CAP is re-connecting after one day or more. The intervals are all different and seem more random on all CAPs. The CAPs don’t re-connect all at the same time. Every CAP seems to re-connect as he likes to.
Today I recognized some timeouts during the re-connect of a CAP to the CAPsMAN in the log of the CAP:
aug/03 17:20:20 system,error,critical router was rebooted without proper shutdown
aug/03 17:20:31 interface,info ether1 link up (speed 1G, full duplex)
aug/03 17:20:34 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
aug/03 17:20:35 caps,info CAP connected to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
aug/03 17:20:35 caps,info CAP joined MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
05:54:39 system,info cloud change time Aug/03/2018-17:23:56 => Aug/04/2018-05:54:39
06:45:39 caps,info CAP sent max keepalives without response
06:45:39 caps,info CAP disconnected from MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:46:12 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:46:32 caps,info CAP connect to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0) failed: timeout
06:46:32 caps,info CAP failed to join MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:46:32 caps,info CAP selected CAPsMAN MikroTik-Keller2 (::ffff:192.168.5.1:5246)
06:46:52 caps,info CAP connect to MikroTik-Keller2 (::ffff:192.168.5.1:5246) failed: timeout
06:46:52 caps,info CAP failed to join MikroTik-Keller2 (::ffff:192.168.5.1:5246)
06:47:00 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:47:02 caps,info CAP connected to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:47:02 caps,info CAP joined MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:49:54 system,info,account user admin logged in from 192.168.5.55 via ssh
06:59:10 caps,info CAP sent max keepalives without response
06:59:10 caps,info CAP disconnected from MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:59:13 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:59:14 caps,info CAP connected to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:59:14 caps,info CAP joined MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:59:32 caps,info CAP sent max keepalives without response
06:59:32 caps,info CAP disconnected from MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:59:34 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:59:37 caps,info CAP connected to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
06:59:37 caps,info CAP joined MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:07:55 caps,info CAP sent max keepalives without response
07:07:55 caps,info CAP disconnected from MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:07:58 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:08:02 caps,info CAP connected to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:08:02 caps,info CAP joined MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:21:40 caps,info CAP sent max keepalives without response
07:21:40 caps,info CAP disconnected from MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:21:43 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:22:03 caps,info CAP connect to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0) failed: timeout
07:22:03 caps,info CAP failed to join MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:22:03 caps,info CAP selected CAPsMAN MikroTik-Keller2 (::ffff:192.168.5.1:5246)
07:22:23 caps,info CAP connect to MikroTik-Keller2 (::ffff:192.168.5.1:5246) failed: timeout
07:22:23 caps,info CAP failed to join MikroTik-Keller2 (::ffff:192.168.5.1:5246)
07:22:31 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:22:51 caps,info CAP connect to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0) failed: timeout
07:22:51 caps,info CAP failed to join MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:22:51 caps,info CAP selected CAPsMAN MikroTik-Keller2 (::ffff:192.168.5.1:5246)
07:23:11 caps,info CAP connect to MikroTik-Keller2 (::ffff:192.168.5.1:5246) failed: timeout
07:23:11 caps,info CAP failed to join MikroTik-Keller2 (::ffff:192.168.5.1:5246)
07:23:18 caps,info CAP selected CAPsMAN MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:23:21 caps,info CAP connected to MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
07:23:21 caps,info CAP joined MikroTik-Keller2 (CC:2D:E0:68:3D:3E/13/0)
I also tried to isolate the problem. I disconnected everything from the lan instead of the hEX and one hAP, the problem resides. I also disconnected the dsl modem of my provider for a specific time and the two left devices showed the same phenomenon.
If I disable RSTP and set the protocol to “none” the CAPs don’t re-connect anymore and everything seems to be ok. The transfer-rates are good everytime.
Every CAP can ping the CAPsMAN, default Gateway is set correctly, DNS servers are set, the connection for every CAP to the internet ist perfect. There is no problem reaching any device on the network. The mentioned problem exists If we are surfing on the internet or if we are streaming and the CAPs are also re-connecting if no one is at home.
I don’t really know what else to analyze. The are no hints where to look at next.
Do you have any suggestions? If you need some more informations about my configuration please ask for it.
Regards,
Jens
