Hi everyone,
I’ve been having regular calls from users that their CAPs have gone down.
When I check in CapsMan/Interface, the broken CAPs don’t show a L2 MTU anymore.
The “broken” CAPs don’t send out beacons anymore, established links break down. When you log-in, they show the normal “CAPsMAN forwarding…” text.
The only things to solve it is to either reboot CapsMan-Router or re-provision the CAPs.
I cannot find any pattern in when and on which CAPs these problems occur.
This is superannoying, I cannot call this deployment stable anymore and users are kind-of frustrated.
Help anyone?
Regards, Robert
