I have ~50Caps in wide area! I have problem - my clients are disconecting for ~10 seconds and then connected back, but clients connection is broken!! Read a lot of topics who suggested
-all caps with Static ip
-try to make all caps work in best channell
Still problem!!
I notice my log - marked with red, it shows regullary with different MAC addresses!
caps,error removing stale connection [A4:8D:8C:D4:11:99/18/7c67,Run,[A4:8D:8C:D4:11:99]] because of ident conflict with [A4:8D:8C:D4:11:99/18/e068,Join,[A4:8D:8C:D4:11:99]]
Some ideas what the problem??
Some ideas what log message realy mean! Cant find documentation about CAP logs!!
Please help! Cant take clients phone calls anymore!!
this is happens, when your cap has dhcp adresses
that is why you cap conecting twice to capsman
to resolve this use static ip on cap
but if you use capsman on main router with wifi and dhcp from isp… you can`t use your wifi with capsman
if you choose winbox - capsman - remote cap, you can see wan ip on you router wifi… it have to be local
